Anybody have any insight to the Model 3/Y battery cooling logic? My Chevrolet Volt had a very aggressive battery cooling logic trying to keep battery less than 30C as soon as plugged in or driving. Of course smaller battery…
I do not have the cooling logic in numbers.
I have 50K km of logs on my M3P with teslalogger though.
My M3P ’21:
It in general do not cool the battery.
It generally (normal driving) never heat the battery, unless the battery is below 0C. When it heat the battery it heats to ”above freezing” to like 3C or so.
The battery often gets 10C or so warmer than the ambient when driving and maybe 15-17C warmer from AC charging at 11kW.
The batt temp is slowly climbing during a long drive. Higher speed means climbing faster and reaching higher temp.
When it is cold enough outside and the heat pump needs heat it takes the heat from the battery to heat the cabin.
Heating the cabin with battery heat is done until the battery reaches(drops to) 12C.
After this the heat pump use ambient air to heat the cabin (or lossy mode if too cold).
Duribg this time the battery temp increases by itself and cooling water fram the engines.
When the battery is at 17-18C, (may take about one hour) the heat pump takes the heat from the battery again, down to 12C.
In cold climate the battery is ”cooled” to take the heat to the cabin.
