Rated range on your car
Discussion in 'Model S' started by Jeffruby, Mar 26, 2014.
Tags:
  1. Jeffruby
    Jeffruby Member
    My p85 shows a "standard" full rated range of 236 miles. Is that what you guys see too? Kind of expected it to be a bit higher.
  2. brianstorms
    brianstorms Member
    How many miles do you have on the car?
    I have an s85 and get 258mi rated range when fully charged. Was 265mi when I bought the car. Car now has 8000mi.
  3. ddenboer
    ddenboer MODEL X #1770
    Austin, TX
    #3 ddenboer, Mar 26, 2014
    I have a P85 and get 247-251 with a 100% (ish) full charge. On my second battery, but it is a refurb rev A.
    And I have almost 33k miles.
  4. purplewalt
    purplewalt Active Member
    Dallas, Texas
    Would you please could confirm if you have your car's charging limit set on 90% or similar, not the full range charge of 265 miles.
    Maybe you could attach a "screen shot" of what your charging level is set for.
    Is your car new, or (slightly) used?
    How many miles are on it?
    The charging level can be adjusted for your daily needs, I set mine for 200 miles.
  5. WeazL
    WeazL Moderator - Hawaii
    Oahu, Hawaii
    I'm usually getting 232-236 miles @ 90% charge on my 85 with 5,200 miles on it.
  6. Jeddi
    Jeddi Member
    Hayward/Tahoma Ca
    My 8.5 month old P85+ with 13.5k usually gets 266 RR.
  7. Jeffruby
    Jeffruby Member
    Yes, my 236 rated range is is at 90%
  8. Liz G
    Liz G P03056
    Wentzville, MO
    My s85 is 14 months old and has 40,000 miles. It seems to have stabilized at 243 for a max charge. Or at least its seemed to be consistent since Oct. The only ime I saw more than that was when I did a couple of trickle charges to full in Jan. Saw 253 for them but returned to 243 when max charging not long after that.
    I'm hoping that what I've heard is true about there being an initial loss but then the battery stabilizes at the new level. So hopefully I won't see anymore loss. Of course though I don't know if this is real loss or calculated loss.
  9. Zythryn
    Zythryn M3 Silver, M3 Midnight Silver
    Minnesota
    Please note firmware version as the algorithm can change.
    On full charge on our S85 I get 253. FW 5.9. 27k miles
  10. Jeffruby
    Jeffruby Member
    Zythryn,
    A) that is on full 100 % charge ie: range charge? Not on the 90% setting for local everyday driving?
    B) Can you manually update to 5.9 or did it push to your vehicle spontaneously?
  11. Chipper
    Chipper Active Member
    Chattanooga, TN
    The only ones who can "manually" update are those in Service Centers.
  12. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    I'll take a shot:
    A: Yes 100%
    B: No. The car downloads the updates and then asks you if you want to install it. Other than Beta testers we've never actually figured out a pattern other than folks with WiFi connections seemed to get them sooner after the update that included WiFi.
  13. Zythryn
    Minnesota
    Al got it.
    We have two, our 85 has received the update, our 60 has not yet.
  14. FlasherZ
    I suspect the OP has an Android phone when referencing a "standard" charge vs. "max range" charge. Unlike those with iPhones, those of us with Android still have the old behavior of "standard" vs. "max range" (or at least I do)...
  15. Jeffruby
    Jeffruby Member
    I do have android. In my car though in the am, fully charged to the "local" setting (which was believe is 90%)- it is at 236 miles rated range. Just seems low. I have no desire to see the inflated higher ideal range.
  16. FlasherZ
    Mine is 240 to the 90% / Standard setting on the replacement battery. It was 228-229 on the original pack after 20,000 miles.
  17. GIdoc
    GIdoc Member
    Michigan
    To OP:
    our 15 day old (new) MS has 236 rated rang on standard charge (I have not done full charge yet). We are on 5.8.10. No 5.9 yet.
  18. Jeffruby
    Jeffruby Member
    Thanks gldoc we are identical
  19. brianman
    brianman Burrito Founder
    Even my non-strict parser has trouble understanding what this means.
    Daily: 50-90%
    Trip: 100%
    "Full" undefined. "Standard" has been deprecated. "Standard full" confuses me terribly.
  20. nrcooled
    nrcooled P#8946 VIN 03225
    NoVA
    This is the exact same rated range and mileage as my B-pack. It was 235 when I first got the car back in Jan '13.
