Rear trunk won't open
Yes it is. I really struggled getting that back in place. If I was to do it over, I would just have mobile service do it. The estimate was very reasonable, but I like to do things myself most of the time.
I know. $40 labor + parts that were cheaper from Tesla than eBay (wish I knew at the time). But it was 2.5 weeks for the appointment and since the car won't lock I couldn't drive it anywhere. I might just keep the appointment and see if they will install the back cover for $40 !
You may be able to lock the doors by touching the lock icon on the center display before exiting. I hear that trick has worked for others in the pat
I’m a longtime lurker who recently joined the stuck trunk club on a road trip with friends. :( Many thanks 🙏 to those who discovered and documented the black plug procedure. With that, I was quickly able to open the liftgate once we returned home.
I’ve spent some time experimenting and playing around with the relevant mechanisms in an effort to gain insight into how the auto-close and open processes are supposed to work. As such, this posting gets a bit lengthy in an attempt to include relevant details. I hope to advance the cause and increase my, and the community's, understanding of this fault. Based on the experiences documented in this thread, it seems likely that this problem would disappear if I replaced the high-torque cinch motor and/or the latch. My curiosity has taken hold, however, and I would like to dig deeper to gain a fuller understanding of what is going wrong.
November 2016 build date Model S
TL;DR — The latch, cinch motor, and supporting infrastructure appear to be functioning properly when inspected individually. How does one bench test the sensors/switches and actuator/solenoid in the latch? My efforts to find a wiring diagram, pinout specs, or troubleshooting procedure have come up empty.
At this point in my experimentation, I’m wondering how to bench test the latch mechanism. My efforts to find troubleshooting procedures, a wiring diagram, or a pinout schematic for the four-pin connector have failed miserably. I’ve used Tesla and Mercedes part numbers in my searches. Still, no dice. I’m hoping that is a testament to my poor searching skills and someone here can point me in the right direction.
When the liftgate is fully and quickly closed by hand (no cinch motor help required), the latch will release as expected. The trouble starts when the cinch motor is activated to fully close the liftgate from a half-closed state. When the latch then opens, the cinch motor does not release. Because the cinch is still drawn tight, the latch only releases part way. The liftgate is then in a partially open state where it can neither be fully opened nor fully closed. The emergency release cable has no hope against the grip the cinch motor has on the latch mechanism.
When the liftgate is in this stuck-in-the-middle state, the black plug method will release the cinch motor. That seems to indicate the cinch motor and associated wiring are intact and functioning as designed.
So, that presents me with a quandary. Why doesn’t the lift gate controller release the cinch motor? Is a sensor, presumably in the latch, failing to indicate the partially opened state? The system seems to know when the latch is partially closed. Otherwise, it wouldn’t have actuated the cinch motor in the first place. Is there maybe something awry within the liftgate controller itself? Maybe the sensor has only partially failed and can indicate when the latch has been half closed from an open state, but cannot indicate when the latch has been half opened from a closed state? A wiring diagram or schematic for the 4-pin connector would be most helpful. Is there a suggested test procedure to further diagnose problems with the latch?
I’ve disassembled, inspected, lubricated, reassembled, and tested the high torque cinching actuator. I found no evidence of malfunction or wear. It readily operates in both directions even with as little as 3 volts from my bench power supply.
I’ve also removed the latch and operated it on the bench. It seems to be working well mechanically with no binding. The emergency release cable opens it up with minimal effort and the cable that runs to the cinch motor operates with no binding or excess friction.
Same thing here. I now have two removed ("faulty") cinch motors. Both spin freely in both directions with very little applied voltage. When I acquire a third that also "works" I intend to take the small (Mabuchi?) motor apart and check on the condition of commutator and brushes.
I don't know if this is the right motor so don't go buying unless you are either certain or don't care about the small cost. https://www.aliexpress.com/item/1005005414164586.html
Adjust the stoppers or remove the cinch, it's not difficult,
Thanks, I might try playing with the stoppers. Removing the cinch / cinch motor, while probably easy for someone accustomed to working on cars, is out of my comfort zone.
(I appreciate how much people have discovered about this issue since it first started happening in 2016.)
Bruce.
Bruce.
Watch the mobile tech perform the service, then look for a good deal on a spare motor over the next couple of years. This way next time it happens, you will be prepared. Working on your own car is not rocket science. The hardest part I think is starting. In this case, if the cinch motor is already broken, you're not likely going to mess it up any worse. If you fail, you just make a mobile tech appointment (one thing I miss from my Tesla days is mobile techs - always had great experiences with them, my parents recently wanted to swap winter to all-season tires on their model Y, turns out even that can be done by a mobile tech - I would have swapped out the wheels for them, as I swap my car 4 times a year and my wife's car twice a year, but they live far from me, not worth the drive).
PS> Purely coincidentally, I was just working on the rear hatch of my latest car (not a Tesla) this weekend - adding some secret sauce of my own to the car, as I did with my Teslas, The only difference between working on a Tesla than other car is that you can lookup howto videos for Teslas, I had to figure out all on my own how to take apart this hatch, so it took way longer (next time it will be quick, will post on the other car forum for others to save them time as I did for Tesla in my Tesla days)..
Bruce.
Putting the back plastic part back on was one of the biggest pains ever (for me anyway).
Yes, and I broke a couple of clips as well.
The very first I did when I got my first Tesla was to get a bag of spare clips, IIRC there was 2 kinds. Back in 2013 Tesla charged me $1 per clip, since I learned you can buy the identical clips for Toyota IIRC (perhaps other brands) for pennies per clip. If you work on your car, there is always a chance a clip can be damaged.
