albert mathews
New Member
This is how I see it. When driving, an ICE powered vehicle has 5 modes of operation for the powertrain in terms of applying toque to the wheels:
1] applying accelerating torque
2] coasting (no engine or brake torque applied) (a.k.a. decelerating due to drag of all kinds)
3] decelerating due to engine braking torque
4] decelerating due to both engine braking and friction brake torque
5] decelerating due to friction brake torque
For this type a vehicle, modes 3,4,5 all results in converting the kinetic energy (or potential energy if constant speed downhill) n to heat (either friction brakes, of heating air via engine pumping loses). Mode 2 also converts the kinetic energy to heat, but not through applying torque to the wheels, so we dont need to consider this here, as this energy cannot be recovered through regen.
An EV can have the same 5 modes, but with one very important difference, "engine braking torque" is replaced by regenerative braking torque. The impact of this is that modes 3 and 4 have reduced the amount of energy converted to heat, as they can store it in the battery for later use. The topic of this thread is whether "coast regen", i.e. applying regenerative torque below a certain "go pedal threshold" is more or less efficient than only applying regeneration torque when the brake pedal is pressed.
The short answer is:
One can develop driving styles for each regen setup such that the same maximum efficiency can achieve with both setups, but developing the driving style which uses coast regen will be easier for the average driver than developing the style which does not use coast regen. i.e. not all of us can drive like the best hyper mileagers.
The long answer is:
Assuming no hills, the car must be accelerated using battery energy, but it can be decelerated by either storing energy back in the battery or by generating heat with the friction brakes. If there is no coast regen, this typically means that regenerative torque is blended with friction brake torque, which means that there is no mode 3, which means the driver uses primarily mode 4 (and to some extent mode 2) to decelerate the vehicle. This means that in order to store energy, the car must also throw some away by creating heat. On the other hand, aggressive coast regen allows the driver to use primarily mode 3 (and to some extent mode 2) to decelerate the vehicle and increase the fraction of kinetic energy recaptured. i.e. coast regen provides drivers with a natural way to increaase recaptured energy without forcing them to massively change how they naturally like to accelerate and decelerate a car.
The long answer is:
