Timothy Meredith
For the record:
If you hadn't attempted to power it on, you may have had a chance by submerging it in deionized/distilled water.
Powering it on basically took this from a "there's a hope" to "no way in hell."
Unless you have discarded them already, I would still try:
1. submerging in distilled/deionized water for about 10-15 min.
2. Put in oven at 85C for some time
repeat until convinced EVERY piece of salt is gone.
Then, visually inspect the traces on the board to see if there are any shorts, use that multi-meter you have to test for continuity across traces that should not have continuity.
If you have shorts... it's a goner. If not, maybe repeat the process another 10-20 times and THEN try to power it up. You don't want to power it up until you're absolutely sure EVERY LAST BIT OF SALT is out of every last bit of space on that board.
Always using dionized water as the salt would dissolve into it.
A little late to the party, but actually the best / most ideal way to clean it (and almost any electronic board) is to use a quality ultrasonic machine (crest) with distilled water + very small amount of electronic cleaner (such as Branson EC Cleaner) for a few minutes tops. Then rinse thorougly with 99.99% pure alcohol.
I've repaired a ton of macbooks in previous business with this method that were thought to be long gone from coffee & wine.
