You're my hero. ℹ
YES! That'd do it (the white pin is the 2.7k pull-down for Prox, thus the error it's presenting). Though I'm surprised it didn't come-up when I was doing earlier testing without even having that resistor there at all... I added it just out of sheer compliance/parity. Turns out, it's necessary after all and mine just may not have been detecting it
But yeah, that's out of place. Here's what makes it worse: this was a pre-assembled one I did
![Flushed face :flushed: 😳](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f633.png)
Whoops. Was a bit frazzled...
View attachment 806458View attachment 806459
So, uh,
@Izzy1315 ~ are you able to move that pin over? First, release the TPA (Terminal Position Assurance - white bar across the edge - you can insert a tiny something-or-other in there and pry up each side to open it), then find something pin-like to push into the release holes on the pins side of the connector (above/beside each pin is a small extra hole - that's the release hole), stuff it all the way in there, and then you should be able to pull the white wire out with gentle force. Move it over a position (
refer to this post), push it in, and use a tool to push the terminal in until it clicks. Then, smoosh the TPA lock bar back down. It'll only smoosh if everything is in position.
See
this post for awesome detailed photos by
@Randy Spencer.
If no, I'll get hustling on building a new one. I'm kinda behind on orders
