NigelM
Recovering Member
I have the right mirror on auto tilt. Maybe I need to play with that setting a bit to get it in the right position.
I have both mirrors on auto-tilt and never had a problem. Best way to set them up is to park perfectly between the lines somewhere (drive in nose first or use an isolated corner of a car park) and then set your mirrors where you can see lines in the ground. Next time you reverse in you should be able to see the lines in both mirrors and be perfectly straight.
