MadScientist
I would put the ride in my LR (18” wheels) a little firmer than my C Class but there’s not a lot in it. I’m more disappointed by the road noise at speeds above 50 mph.
That's just because the rear springs are a lot stiffer than the fronts.Thanks. I’ve had a quick look but can’t see anything obvious. Waiting for a trolley Jack and some lifting pucks so I can get a wheel off and have a proper look.
In a totally non scientific test pushing the back down (boot lip) generates almost no movement whereas I can get more out of the pushing the front down (frunk lip) I’m not what you would call small so can put a fair bit of force down!
Just turn the stereo up!I would put the ride in my LR (18” wheels) a little firmer than my C Class but there’s not a lot in it. I’m more disappointed by the road noise at speeds above 50 mph.
Would also say that if I break hard there is no downward movement at the front of the car stays perfectly flat. Under hard braking I’d expect some downward movement at the front.
I came from an X3 but had a 328, M135 and Scirocco before and the ride is significantly worse than any of those. Still live in the same are so same roads.
Get an S if you want a barge.I have just exchanged my Performance for an LR. Both have exactly the same ride and overhard suspension. Particularly bad with speed bumps. My Mercedes used to take all such surfaces at speed without any drama.
The Tesla really is more of a Ford than a German lux car.
Maintaining a flat attitude under braking is what you would aim for in a sporting vehicle. Why would you want or expect the car to dive?
Nothing to investigate there.I don’t want it to dive particularly. Just used to a car nosing down under heavy breaking and the M3 doesn’t so wondered what others were experiencing and if my experience was different and therefore something to investigate.
I would agree with this. I had a CLS which is essentially an E-class with it's going-out trousers on. Found the same, I much more direct steering and lively suspension. When you go from a large sedan or estate built for comfort with air suspension and long like seats to a sporty saloon car you expect a reduction in comfort. The massive improvement in handling more than makes up for it.went from e-class (wallow wallow but soft and cossetting) to M3LR. Agreed on some of the slightly ropey A roads you do feel more i.e. it does not absorb as much as the E-Class does for example, but it's ability to grip and stay flat is astonishing it's very point and dart unlike the Mercedes which you did not so much drive, as make suggestions
