PokerBroker
Ask them if they will apply your coat today to the purchase price of the upgrade when it is available in order to keep you moving today.
checking in on the to-do list: real world demo, specs, prices (a la carte, please!), warranty...:frown:
(as compared to the new battery which may provide a 40 to 60% increase in range?)
I'm hoping that all the other pieces (aero kit, wheel bearings, brake modifications and different tires) together will be much less expensive than the new battery but will still provide a 20 to 25% improvement in range...
Tesla definitely did not say the Ideal Range will be 400 miles. Ideal Range means something very specific: the result of the 2-cycle EPA test, which in real life means range on level freeway in moderate weather at a steady speed around 55 mph.But Tesla is saying essentially that the Ideal Range of the 3.0 version will be 400 miles as compared to the 245 of the Roadster when it was brand new.
That statement is actually true with the original Roadster pack, it's just that the set of speeds is 14 to 22 mph* in moderate weather. The question is how much faster the new pack will allow you to go and get that range.There is a set of speeds and driving conditions where we can confidently drive the Roadster 3.0 over 400 miles.
That can actually be deduced from the second "lost" chart - power vs. speed:That statement is actually true with the original Roadster pack, it's just that the set of speeds is 14 to 22 mph* in moderate weather. The question is how much faster the new pack will allow you to go and get that range.
Do we expect the battery to be lighter, or the same weight? That could affect some factors, but probably not my much.New battery is supposed to have ~1/4 higher capacity, so average power for same distance can be 1/4 higher, around 4kW or 28 mph.
Add improved bearings and that speed may rise to ~35 mph.
Well done!New battery is supposed to have ~1/4 higher capacity, so average power for same distance can be 1/4 higher, around 4kW or 28 mph.
Same, give or take 50 pounds, not more/less.Do we expect the battery to be lighter, or the same weight?
