Got it. Thanks. I guess I'll go ahead and order it then.No, let me clarify. Even if I received the Roadster Foundry License Plate Bracket, I wouldn't have plates to put on it yet... but yes I've heard they fit the 2.5. I will upload pictures when I have them.
I didn't have it installed but it looks like one hole into the black plastic (grille) and not the body of the car. Not sure about airflow but what I'll do tomorrow or Saturday is take some pics or video to demonstrate. I'll also dcument the foundry "install".
I finally got my plates... just impatiently waiting on the bracket.
Sadly, however, I searched the interior of the box and cannot find anything except the bracket. ...
Another interesting point. The header on the instruction sheet states, "Front License Plate Bracket for 2008 Tesla Roadster." Either they need to update that or I am in trouble. I'll try a dry fit later and report back.
Would you recommend to Foundry Bracket over the factory bracket (that drills three holes into the plastic grill)?
Had to get an M10x1.0 bolt and snap-ring washer (OSH has a pretty impressive selection of metric hardware for you Left Coast folks)
Ack, you're right. Old memory isn't what it used to be. M10x1.5. I'll edit my post above.
Does the Foundry bracket not come with everything you need or was it just missing? Thanks.
The M10 bolt, split-ring washer, and Allen wrenches were supposed to come with the bracket but were missing. You are supposed to use the M6's that came with the factory bracket to attach the plate to the bracket. However I told TM to keep the factory bracket to reduce the clutter in my garage and help the earth by allowing them to give it to someone else. So I didn't have any front hardware.Does the Foundry bracket not come with everything you need or was it just missing? Thanks.
