I really don't get why everyone is so down on the brakes. I understand that they kind of feel weak, but as far as I can tell all that means is that you need to push them a little harder to get them to work.
< CUT >
But, I'd expect a larger Roadster pack would have a better 0-60 than a smaller one (until it hits the limit of the tires).
If you keep the brakes clean then they are OK ish but they still lack initial bite which is one of the things that gives you confidence. You can lock the brakes / get the ABS to cut in at normal highway speeds but not say at 80mph.
As far as I know the brakes are pretty much the same as those fitted to the original S1 Lotus Elise which was 1000lbs lighter than the Roadster (not thats not a typo, 1000 lbs lighter) and had I think 120 bhp.
R&T give the following test data for 80mph to zero braking
188ft 2005 Lotus Elise
210ft 2010 Tesla Roadster Sport
OK in % terms its not huge but if the stationary object is 189ft away from you.... Its not just a weight thing, many cars heavier than the Roadster can do 80 to 0 in <200ft according to the R&T data. Eg the 911 turbo is nearly 1000 lbs more than the Tesla but stops in 185ft.
As for the bigger pack delivering more power thats a good point. With advancing technology its certainly possible to make a new battery pack for the Roadster that will give the same range but will less weight using a smaller number of higher capacity cells. I dont know if these newer cells can actually deliver a higher peak power though. Perhaps someone else here knows?
