Here are a couple of interesting charts.
The first is % battery loss per 10K miles, charted are the 17 vehicles with at least 14K miles.
The line shows that you can expect about 1.75% loss per 10K miles ... if you look on the right at the high mileage cars, the low mileage cars are highly variable.
This one is %battery loss per 10K miles on the horizontal axis.
The stacked charts are % time at different SOC levels. ( The vertical axis is time - totaling 100% not SOC )
T0-15 means time at SOC between 0% and 15% inclusive.
T91-100 means time at SOC between 91% and 100% inclusive.
The vehicles that spend a lot of time >= 86% SOC or below 15% SOC tend to be on the right ( higher %battery loss per 10K miles )
It is consistent with the rule of thumb: don't leave your battery full or empty for long periods of time.
Major caveat: I need to do a bunch of work to verify this data. It might be from a very small sample of the vehicles life and thus not very reliable.
Final note: I defined % battery loss as the % drop of the last "brick ah ave" number in the log file from 159.
