FYI, ChargePoint is sending announcements about new DC Fast Charging locations, where the DC option is SAE Combo only:
22kw is too slow to be meaningful for longer travel outside of the supercharger network. Ohh, and a 22 kw station kind of sucks if there's a 48 kw ccs beside it.
The complaints from Europe are entertaining. Supercharging density in many parts of Europe has exceeded North America already, and the 2016 map is insanity. In addition to this, you have plentiful ~240V outlets. You realize that in North American the standard outlet is 12A @ 115V, basically a meaningless amount of charge. Then almost all the level 2 chargers are <6kW J1772 stations as they are 30A and usually 199V after sag on industrial 208V. You can find ChaDemo (which is fortunatey or unfortunately co-located with CCS depending on how you look at it) if you are very lucky, but mostly they are located in useless places, like in heavily populated places where there is a Nissan dealership or a supercharger already, basically no where you'd need them "outside of the supercharger network".
I'd kill for a 10kW charger in many areas, forget about 20kW, that would be a dream. Well unless Tesla finally decides to add a supercharger in those locations.
Still, I think that for Europe Tesla should and probably will change their socket so that it accepts SuperCharging and CCS without any adapter.
I highly doubt that will happen. The CCS/Combo plug is so large that the current Model S charging port would never accommodate such a plug. I doubt Tesla will ruin the aesthetics of the car for such a plug.
Tesla engineers have said a CCS adapter doesn't require any electronics, as the CHAdeMO one does, since both Superchargers and CCS use powerline signalling, not the CAN bus. It should just be a larger version of the J1772 adapter. Tesla was on the group that defined CCS and has stated that the protocols are compatible, whatever that means. SAE took too long to actually approve it and it's a bit under-powered as well.Hence the name "Frankeplug" its a monster!
I would expect to see an adapter that looks similar to the ChaDeMO. CCS will be the standard deployed standard in the US going forward. Chademo will be around awhile due to the Large amount of Leaf's out there.
Source?Tesla engineers have said a CCS adapter doesn't require any electronics, as the CHAdeMO one does, since both Superchargers and CCS use powerline signalling, not the CAN bus. It should just be a larger version of the J1772 adapter. Tesla was on the group that defined CCS and has stated that the protocols are compatible, whatever that means. SAE took too long to actually approve it and it's a bit under-powered as well.
The point about "compatibility" was stated a long time ago (and I've never seen it in words as explicit as yours), but it seems to have been misleading. All indications are that Supercharging starts with the 'go to digital signalling' pulses as specified in J1772 (same as CCS), but then CCS uses powerline carrier while Supercharger appears to use simple CAN.
JB Straubel disagrees with you, what's your source?The point about "compatibility" was stated a long time ago (and I've never seen it in words as explicit as yours), but it seems to have been misleading. All indications are that Supercharging starts with the 'go to digital signalling' pulses as specified in J1772 (same as CCS), but then CCS uses powerline carrier while Supercharger appears to use simple CAN.
To be fair, while I also reference that quote, people who have examined the supercharger protocol says that it starts the analog half like CCS, but then the digital part is completely different (as others mention, it uses CAN, not PLC). Of course it is possible that the car has hardware that can support PLC (given how much dissecting has been going on, maybe someone can chime in if they know) and just requires a firmware update to enable it when the adapter comes.JB Straubel disagrees with you, what's your source?
SAE: What about the communication protocol of the Combo Connector? It’s considered essential for V2G.
Straubel: That’s fine. We’re definitely commonizing with all of that. The only thing that’s up for debate in all of these standards is the physical geometries of the pins and sockets. Everything else is pretty easy to adapt to. The communication standards are pretty universal. We’re 100% compliant with all the J1772 communication levels, signaling, voltage, everything.
http://articles.sae.org/11923/
Source?To be fair, while I also reference that quote, people who have examined the supercharger protocol says that it starts the analog half like CCS, but then the digital part is completely different (as others mention, it uses CAN, not PLC). Of course it is possible that the car has hardware that can support PLC (given how much dissecting has been going on, maybe someone can chime in if they know) and just requires a firmware update to enable it when the adapter comes.
You can see starting from here:Source?
Someone playing with monitoring the supercharger communications really doesn't seem as authoritative a source as JB Straubel speaking to a professional magazine. "Extraordinary claims require extraordinary proof"
The quote was in answer to a specific question about the SAE combo connector and DC charging. While I suppose it's possible that the J1772 protocol isn't possible to be changed or extended in the Tesla car's firmware, I find that pretty difficult to believe. The CCS protocol is still HomePlug PLC, the same as J1772 anyway.<snip>
Strictly speaking, that isn't in conflict with the precise words you quoted above - the car does do all that's in J1772, since J1772 itself only covers AC ...
<snip>
The original question was if a "dumb" CCS adapter could be made for Tesla cars' charging connectors. An alternative formulation of the same question is if the Tesla car's connector is "compatible" with CCS.
CCS uses "Power Line Control" (PLC) signalling,
as does J1772, and apparently the start of the Supercharger protocol,
