No. I was on maybe a 3% incline if that.Did you use full regen on a steep downhill during your drive?
It doesn't seem to me we should be penalized in any way by any kind of (manual or regenerative) braking on a steep hill to keep in the speed limit. This is kind of dumb.If you actually braked your score would probably have been better. It says it's based on time braking so braking hard for a shorter period of time is better than braking right over the 0.3g threshold for a longer period of time.
Better would be to not use full regen (keep very light pressure on throttle) on hills so you slow down but not quite as hard. I agree that this is tricky.
Only the steepest street in the country would give 0.3g while maintaining speed. That would be a 30% grade.It doesn't seem to me we should be penalized in any way by any kind of (manual or regenerative) braking on a steep hill to keep in the speed limit. This is kind of dumb.
IMO, do what’s safest. Which (again in my opinion) is take over.I almost got into a crash last night as I was tooling down the freeway in NOA. Someone inattentively swerved into my lane and while NOA was reacting I proactively dropped AP and braked. In these situations AP does very well, but it's 50/50 as to who reacts first. That registered as 1.3% hard braking for the day. It's not a serious ding but I wonder: if I'd let AP complete the evasion it would (obviously) also have had to brake, so would THAT count as hard braking? Is it better for your score to just CYEP? close your eyes and pray?
Does anyone have an idea how they came up with those factors? I get the Autopilot disengagement and hard breaking have the greatest impact, but my little brain has a hard time understanding why those numbers? I would have thought they could have come up with something simpler.
I would have also thought unsafe following would be higher, but maybe because it is not a consistent measure.
Unsafe following doesn't count if you are on autopilot. It is the percent time you are 1-3 seconds behind the lead car minus the time you are within 1 second. Not easy, but can be changed.Bullsh¡t.
I got 100 score every day driving an average of 30 miles a day.
My wife drove the car once for 20 miles and brought my score down.
My unsafe following score is fixed now at 9.3% which was my wife's score during that short drive. No other driving compensates for that even if it's perfect.
The safety score is more rigged than the election.
I took a long drive to get the denominator up (miles driven) and had to do a 'both scroll wheel' reset (while driving) because my wipers were on for no apparent reason. It fixed that issue but I then noticed it didn't count the drive in the safety score. Is that because I lost connection while reseting the screen?
The point you are making is correct, but your wording isn't exactly accurate: it's the time spent following within one second divided by the time between 1 and 3 seconds. That is, it's the ratio not the difference. As some have noted, the way to improve this score is to spend a lot of time following within 3 seconds but not as close as 1 second, so as to increase the denominator without affecting the numerator of the ratio. (And, in fact, unsafe following is the least impactful to your overall score, so it isn't nearly as important as hard braking. Which is why novox77 correctly advocates for doing "some low speed full regen decelerations on a quiet road" -- this is absolutely a good strategy if you have non-zero hard braking time on your current trip).Unsafe following doesn't count if you are on autopilot. It is the percent time you are 1-3 seconds behind the lead car minus the time you are within 1 second. Not easy, but can be changed.
Well given that every study and recount has proven the election was not rigged, then your comment holds no real value. I bet you think vaccines cause you to be magnetic, that it’s the mark of the devil, and that an RFID chip is implanted into all those getting vaccinated.Bullsh¡t.
https://www.tesla.com/support/safety-scoreDoes anyone have an idea how they came up with those factors?
The current formula was derived based on statistical modeling using 6 billion miles of fleet data.
Yep...that seems to be the general consensus. And remember, the corrective driving needs to be on the same day as the ding.So I need to work on my unsafe following parameter.
Am I correct in understanding that I will only be able to improve it by driving without AP and between 1-3 sec following distance?
Doesn't seem like maintaining a 3+ distance or AP helps this parameter in any way.
Yep...that seems to be the general consensus. And remember the corrective driving needs to be on the same day as the ding.
