Thanks !I'll let LayZ know you're interested, since I guess you won't get a reply from here.
I dont have a salvage car yet but I plan to buy one for cheap and do diy for fun. On electronics I am not that great soldering expert especially for fpga or smd I think I risk killing the board, but know Linux and command shell very well so no big worries on that side. You refer to a 'switch' to enable fast charging what kind of switch you mean? A variable in a config file or a phisical switch/fuse? I am honest to pay for charging no need to get free SUC I guess they will block FIN anyway, but a CCS charging in Europe or chademo whould be a huge benefit I am located in germany.WAMZ: I only know what I've experienced and figured out for myself, and that's all rooted.
Kitt_De: There's a good reason for that. SOME ppl are unethical and seek to enable supercharging when it was not paid for. All DC (fast) charging relies on the same switch. If you're honest maybe you can figure it out. On the SIM yes as long as it's compatible with AT&T (3G or LTE as the daughtercard may be) and you pay for the account, but why? Idk about Spotify as I don't use it, but I believe yes.
That's fine, I'm sure you can outsource all your soldering needs.I dont have a salvage car yet but I plan to buy one for cheap and do diy for fun. On electronics I am not that great soldering expert especially for fpga or smd I think I risk killing the board, but know Linux and command shell very well so no big worries on that side.
It is a software switch (gateway configuration), although there seem to be hardware ways of disabling SC at a supercharger, so I would avoid superchargers.You refer to a 'switch' to enable fast charging what kind of switch you mean? A variable in a config file or a phisical switch/fuse? I am honest to pay for charging no need to get free SUC I guess they will block FIN anyway, but a CCS charging in Europe or chademo whould be a huge benefit I am located in germany.
I think you should be able to do that (I actually plan to do that). You can even change the sim card in the MCU, but I'm not sure if it will recognize the new APN, or if you need to change it yourself. In any case, you can change the APN if you are root.About the Sim I refer to the only services and those seem to be disabled on salvage cars as well so the question was if I use my own mobile internet card if the car gets mobile internet again and if I can use my own Spotify account to get some music. So it does not need to be the same operator tesla uses or does it?
That's great! I enjoyed a lot bringing my model S back to life, I hope you also have lots of fun! Let me know how it goes.This would be all more like a fun project to learn the tech and repair a used car. I have my daily driver (Model S) but want to do some diy on a Model X and get or build a car for cheap like 'Rich rebuilds' on youtube
Hi! My two cents:My questions:
Any help would be greatly appreciated.
- Do those issues sound like it has been rooted and modified to disable those settings?
- How do I know if it is rooted?
- Can I re-enable traction control, stability control, and regen by gaining root access? ...or at least be able to troubleshoot the issues?
- If it is not rooted, where do I start to learn how to do so? (I am a software engineer so not a stranger to code but new to rooting a Tesla)
You're right on port location, theres a triangular panel that is a little flimsy as you open the door on the console due left and down from the IC. you'll need to create an HSD cable out of ethernet or buy one.Hi! My two cents:
1. As far as I know, your errors have nothing to do eith rooting.
2. 2018 fw are rootable (if it's a typo and you're on 2020.48, I'm 99% sure it's not rooted). Most likely if it's rooted the diagnostics port will be open. I'll sketch a bit how to check this, and if you want more info, you can dig in the forum, or get back to me. Usually this is behind the cubby, below the display, but your Tesla is 2013, and if I remember well, it might be somewhere else. You'll need an ethernet to HSD adapter to communicate there (you can build one with a soldering iron or buy it for ~$50), and then you set up a local network and try to ping the cid (I think it's 192.168.90.100). If you get an answer, it's rooted. This procedure won't tell you how to access the car, though (you might need to root it... again).
3. You can't, but if you get a terminal window, you can check the alerts and you might get a little bit more of info of why these are disabled. Don't the errors go away when you drive a few miles (~5 or 10 mi)? Factory mode might also help.
4. The 2018 fw might be rootable with the soldering/desoldering method, which is well documented, but you might want to check before disassembling the MCU. Otherwise, you need a vulnerability, and these are not disclosed (not even for old fw!). In any case, and since your fw is pretty old, you might find something digging in this forum.
Good luck!
Yes... this is what I vaguely remember, on driver's side, right? The panel that would be behind the rear view mirror. Thanks for clarifying.You're right on port location, theres a triangular panel that is a little flimsy as you open the door on the console due left and down from the IC. you'll need to create an HSD cable out of ethernet or buy one.
ape bms cc chgph1 chgph2 chgvi cmp cp das dcdc ddm dhfd dhfp
dhrd dhrp di dis epas epb epbm esp gtw ibst ic lft msm ocs
park parrot pdm pm pms ptc radc rccm sccm sec sierra sun tas
tcid thc tic tpms tuner umc
after
after-e
after-e
after-e-ms
apeb-checkapesig
apply-bsdiff
apply-rbvrm-delta
auth
auth.part.57
check-prohibited
check-sd-card
checkkern
checksig
checksystem
cleanspool
debug
die
dispatch-as
download-secondary
examine
examine.part.169
example
factory-redeploy
format-sd-card
fwheartbeat
gateway-update
get-boot-mode
get-bootloader-status
gostaged
guarantee-pcc
gwcmd
gwping
gwver
gwxfer
handshake
hashpart
hostip
HTTP-GET
HTTP-GET
HTTP-GET-onclose
HTTP-GET-restart-command
HTTP-POST
hwidacq
ice-ecu-redeploy
ice-ecu-redeploy.part.188
ice-umc-redeploy
ice-wc-redeploy
install
internal-dat
keepawake
kexec
kexec.part.108
kill
kill-paths-pending
launch-factory-redeploy
logfd
m3-factory-deploy
m3-factory-deploy-done
match-or-die
md5sum-file
not-manifest-list
not-package-list
not-redeploy-kernel
offlinepatch
onlinedup
override-handshake
override-version
periodically-until
pet-watchdog
phase-car-control
ping-updater
post-gwlogs
post-misc
qber
queue-tftp-data-on-sid
quickboot
read
read
read-signatures
reboot
redbend-dummy
redeploy
reexec
reexec.part.116
remaster-release-tgz
repair-bootloader
replace
report
report-vin
reset
respool
retry-gostaged
retry-gostaged.part.185
rqflush
serve
service-redeploy
session-exit
set-handshake
set-parker-boot-mode
setenv
setrlimit
setrlimit
sierra-update
signature-redeploy
signature-resolution
sitemaster-report
status
stealth-gostaged
stealth-gostaged.part.184
swap-updater
swatch
system
termination-status
test-bootenv
test-verify
troubleshoot-offline-signature
try-syncterm
tuner-report
tuner-report.part.118
tuner-shutdown
tuner-update
tzset
tzset
uinotify
unwatch
update-bootloader
uptime
uptime.part.43
wake-remote
watch
wifi-watcher
Updated link?I don't. Anonymousfiles.io is a actually a widely respected site for zero tracking uploads. It's only as dangerous as the file you download. But eitherway you need to trust the torrent content and I suspect if you have a webfilter/AV thats warning you about Anonymousfiles.io your getting have troubles with the Torrent being blocked as well.
But rest assured, the website itself does not push or infect with malware. Thats not how it works.
I tried a factory-redeploy and a service-redeploy (not sure of the difference) but no dice. So then I updated to 2019.40 and it all started working again. No problem with WiFi or 3G. Seems like something in my car doesn't like 2019.12.1.1 firmware. I'll try install again from 2019.40 and see if the problem comes back.Try restaging the firmware in cid-updater with service-redeploy .
You can also specify particular modules such as:
Code:ape bms cc chgph1 chgph2 chgvi cmp cp das dcdc ddm dhfd dhfp dhrd dhrp di dis epas epb epbm esp gtw ibst ic lft msm ocs park parrot pdm pm pms ptc radc rccm sccm sec sierra sun tas tcid thc tic tpms tuner umc
Some more handy and/or dangerous cid-updater commands:
Code:after after-e after-e after-e-ms apeb-checkapesig apply-bsdiff apply-rbvrm-delta auth auth.part.57 check-prohibited check-sd-card checkkern checksig checksystem cleanspool debug die dispatch-as download-secondary examine examine.part.169 example factory-redeploy format-sd-card fwheartbeat gateway-update get-boot-mode get-bootloader-status gostaged guarantee-pcc gwcmd gwping gwver gwxfer handshake hashpart hostip HTTP-GET HTTP-GET HTTP-GET-onclose HTTP-GET-restart-command HTTP-POST hwidacq ice-ecu-redeploy ice-ecu-redeploy.part.188 ice-umc-redeploy ice-wc-redeploy install internal-dat keepawake kexec kexec.part.108 kill kill-paths-pending launch-factory-redeploy logfd m3-factory-deploy m3-factory-deploy-done match-or-die md5sum-file not-manifest-list not-package-list not-redeploy-kernel offlinepatch onlinedup override-handshake override-version periodically-until pet-watchdog phase-car-control ping-updater post-gwlogs post-misc qber queue-tftp-data-on-sid quickboot read read read-signatures reboot redbend-dummy redeploy reexec reexec.part.116 remaster-release-tgz repair-bootloader replace report report-vin reset respool retry-gostaged retry-gostaged.part.185 rqflush serve service-redeploy session-exit set-handshake set-parker-boot-mode setenv setrlimit setrlimit sierra-update signature-redeploy signature-resolution sitemaster-report status stealth-gostaged stealth-gostaged.part.184 swap-updater swatch system termination-status test-bootenv test-verify troubleshoot-offline-signature try-syncterm tuner-report tuner-report.part.118 tuner-shutdown tuner-update tzset tzset uinotify unwatch update-bootloader uptime uptime.part.43 wake-remote watch wifi-watcher
If I remember well, there was a big change in 2019.40 regarding connectivity. But I don't think it should affect you that way.I tried a factory-redeploy and a service-redeploy (not sure of the difference) but no dice. So then I updated to 2019.40 and it all started working again. No problem with WiFi or 3G. Seems like something in my car doesn't like 2019.12.1.1 firmware. I'll try install again from 2019.40 and see if the problem comes back.
How do you specificy to redeploy a specific module? service-redeply "bms" or what?Try restaging the firmware in cid-updater with service-redeploy .
# nc localhost 25956
> service-redeploy
would do it all.
> service-redeploy "update_component_list"
> service-redeploy "update_component_list":"du,pm"
would just do the du and pm
No I don't think so, it was running an old version v8.1 up until recently and that had no problems connecting. Yesterday I went back to 2019.12.1.1 again and the internet connectivity problem returned. So there is a problem with that firmware and my car.If I remember well, there was a big change in 2019.40 regarding connectivity. But I don't think it should affect you that way.
Looks like you're correct, I went back to 2018.48 today and still no connectivity. So now it looks like anything before 2019.40 causes a problem with internet connectivity when downgrading firmware. I wonder whyIf I remember well, there was a big change in 2019.40 regarding connectivity. But I don't think it should affect you that way.
I restored internet connectivity by copying a backup of p3 to /var/ Later firmware versions must have deleted or changed a file in there.Looks like you're correct, I went back to 2018.48 today and still no connectivity. So now it looks like anything before 2019.40 causes a problem with internet connectivity when downgrading firmware. I wonder why
