I can see where the homes and businesses in the heavily forested or steep terrain and more susceptible to wildfire spread and harder to handle would have different rules. Distance from firehouse and accessibility of roads would also be factors. With wildfire season lasting more months and temps hotter and landscaping drier, not surprised they are trying to tighten up code. As a homeowner I wouldn't be happy with the retroactive part if I was in middle of my install and now couldn’t finish as planned. Especially tough on installers who have to accommodate the changes or lose out on planned projects where the cost or design no longer makes sense.
I get your point about the flour LOL. And what was that flour going to be used for?
BTW I don’t recall the State (some reason think it wasn’t Calif.) but someone on here said his fire dept was requiring a fire enclosure of some kind around his planned PWs.
Sadly the wild land rules aren't different, though I think that they should be. There are all sorts of venting and construction materials that are allowed, as if the building was in a downtown area, but it isn't. E.g. I think that in wildland areas, all crawl spaces should be sealed or covered with maximum 1/16" screening, no gable vents, no fancy roof lines that accumulate leaves and embers, metal covers to gutters, or no gutters, only inorganic roofs, etc. There are recommendations for fire hardening the area around a house, but no requirements, e.g. fireproof decks, stone/concrete landscaping, minimum distances to shrubs, and trees, etc. The homeowner gets no credit for doing these things, and some items may even be against local codes, though meeting national best in class recommendations. We mow and use cattle to keep the fuel load down below the house. My vents have fine screening, gutters are enclosed, and I have something like 200' of nonburnable area below the house, and brick under my nonflammable deck. My neighbor has 9', and a wooden trellis and shrubs under his deck. Similar houses, but radically different fire exposures.
I would love to get credit for more/better water storage, water access points, etc., but that's not the system today.
The flour was corn flour to ferment into ethanol (for fuel use). Funnily enough the Fire Marshall didn't voice any concerns about the ethanol. If you have ever tried to ignite a pile of flour, it is pretty resistant to ignition, unless you suspend it in air, at which point nasty things happen very rapidly.
Lots of codes aren't logical. The NFPA storage codes for chemicals are different than OSHA, which is different than the EPA. You do your best, and know that when the other agency audits you, you will get dinged and have to move certain items into different storage areas, which will get you dinged by the next auditor. Lather, rinse, repeat....
All the best,
Peter
