I've been thinking about converting a substantial part of my TSLA shares to cash in order to generate capital by weekly/biweekly OTP BPS selling.
In a perfect world where you could time everything perfectly, you'd make this switch after a huge SP rally, hoping to sell at a local top.
The main consideration is "can you get a safe minimum weekly return that outperforms the stock in the long run?".
In the short term the stock can rally hard and no amount of safe spread selling will net you similar results. On weeks where TSLA is down, even by a large amount but not insanely large, the cash based approach will win out hugely.
After running some numbers, I'd like to present them here in order to get some feedback.
Currently a 2% weekly return seems doable with safe spreads. Safe in my mind is either very wide (+650p/-1050p-) or far OTM (+750p/-900p). Both of these will net me more than 2% return. Combining the safety nets of width and distance OTM is more difficult. After all, once you get too far OTM (below 850 for example) the premiums are basically the same in $ value, even if you go $100 further OTM. So a super safe +500p/-900p will not get you the desired weekly returns to outperform the stock in the long run.
By the way, the reason I have 2% minimum in the back of my mind is because, starting from $1068 SP today this would mean the stock would have to reach over $2900 by end of 2022 in order for the cash route to be less profitable.
At 1% weekly returns HODLING seems safer: the SP only needs to go to around $1800 by year end and that is within the possibilities IMO. ($2900 is also 'possible' but way more unlikely if you ask me).
Also, if you get minimum 2% per week you might go over some other weeks. There are relatively safe spread to be found with 3% weekly returns as well, and if you can get some of these in from time to time (depending on the current position of the SP withing the trading channel) it truly seems difficult for the stock to outperform cash.
Of course, if I were to do this, I'd have very strict rules in order to preserve capital, way stricter than I'm currently trading options. To scratch the "trading itch" I think I would use (for example) 2/3 of my cash for safe income generation and the other 1/3 could act as a seperate options trading (virtual) account like I'm doing now. (Right now my balance is: 3/4 TSLA HODL , 1/4 cash which I grow with options).
Another benefit of going cash is recession. IF there were a recession and the markets all give back 30%, I could buy back more TSLA than I sold. Of course this is A) timing the market which I don't believe anyone is capable of and B) a non-argument since the opposite can happen as well: a 2 year bull market after you convert to cash in which your stock returns would've been higher than "safe" options selling. So this argument seems to only matter if you convert TSLA to cash on ATH.
Pardon my ramblings, I'm just sharing my internal reasoning. I've been dipping my toes into this thread and option selling since May 2021 and checking my returns (+5% per week on average) I notice they are much higher than I expect the stock to gain (in the long term, short term anything can happen for example if FSD were to release or something). I am aware of the fact that this is only true for TSLA option selling. I've dipped my toes into selling options for other underlying, but these returns are abysmal compared to TSLA. Volatility and volume are king.
I started out very small in May (only $15k cash or so). After some learning I (on purpose) let a cc expire and I've been using that cash for option selling also.
Now I'm wondering if I should convert some more shares but I keep thinking there must be a catch. As we always say: If the risk is unclear, it's because you didn't look hard enough.
Therefore I would appreciate some feedback regarding my thought process and mainly:
- is 2% per week truly possible on consistent basis? Or higher, lower?
- what risks am I not seeing?
- will the TSLA options market dry up in a couple of years when TSLA stabilizes? WDYT?
Good day to all.
A consistent return of 2% per week is difficult to achieve without running a risk. I consider weekly positions that are 25% OTM to be risk free, maybe 20% in less volatile times. But premiums on those positions will not give you a 2% return per week. I think 1% to 1.5% is more realistic, especially if you account for a losing position once in a while.
