USB sticks tend not to be durable enough to take all of the writes and may not last long. SSD get around this just by sheer size. i.e. spread the load but its an expensive solution. Can I suggest Sandisk "max endurance" micro SD cards. They are designed for exactly this use case and should last at least 5 years.I bought a second usb stick as the original one might be a bit flaky but will try a ssd instead at some point.
Think my factory fitted usb stick was a intermittent problem, with the second one it's working reliably.USB sticks tend not to be durable enough to take all of the writes and may not last long. SSD get around this just by sheer size. i.e. spread the load but its an expensive solution. Can I suggest Sandisk "max endurance" micro SD cards. They are designed for exactly this use case and should last at least 5 years.
For now...... I have never yet seen a USB stick with the on paper write durability suitable to use as the storage for a Tesla or any other dashcam.Think my factory fitted usb stick was a intermittent problem, with the second one it's working reliably.
Where will the micro SD cards go? Is there a micro SD card storage option in Tesla?USB sticks tend not to be durable enough to take all of the writes and may not last long. SSD get around this just by sheer size. i.e. spread the load but its an expensive solution. Can I suggest Sandisk "max endurance" micro SD cards. They are designed for exactly this use case and should last at least 5 years.
You will be able to buy a USB card read/write holder to replace the USB stick that’s thereWhere will the micro SD cards go? Is there a micro SD card storage option in Tesla?
Yes. I get event notifications, but nothing shows up in the viewer. The last event was about 3 weeks ago (until I tried reformatting it, with no luck). Dashcam clips save just fine and can be viewed just fine, but Sentry clips don’t save.I got the same problem I've formatted my USB stick and I'll get sentry notifications in the car but no way to view them since the V11 update. Anyone else having this issue?
The first patch update after the holiday update fixed my sentry mode.Did you get a solution to this? I have the same issue. If i hit record it does. But Sentry does not record on its own. Nothing is there even when it tells me an event was detected.
I did that and now the first stick is working again.I've now got this as well - after the update to V11 no sentry (even though there are notifications) - tried formatting the stick (which seemed to complete fine) now no dashcam recordings either...
My plan is software reset then new stick...
I found the fix for my problem. Sentry was turned on with the red button displaying, but record, the button to the left of record was not on. It also has to be on for Sentry to work.Did you get a solution to this? I have the same issue. If i hit record it does. But Sentry does not record on its own. Nothing is there even when it tells me an event was detected.
