just finished 2nd service $787. Here's what was done and found...
1- Removed all bolts for the arm rest and applied thread locker. Then re-installed armrest
2 - Four Wheel Alignment - Adjust Only (Coil Suspension)
3 - WIPER BLADE ASSEMBLY - DRIVER SIDE, WIPER BLADE ASSEMBLY - PASSENGER, BATTERY LITHIUM COIN 3V 20MM, Carbon filter, R134A REFRIGERANT, BRAKE FLUID DOW SERVICE 1 QT, Desiccant Bag - Subcool Condenser, 37g
4 - Driver window wasn't going up; Installed new left front window regulator assembly. Adjusted, calibrated and then tested operation of the window.
5 - Replace LH Front Door Handle Seal, Re-positioned door handle backing plate, installed 4 fasteners into backing plate
