TSLA at $177.92
Here are some of my thoughts on current TSLA price action.
I've mentioned several times the bullish flat base pattern forming over the past 3-4 weeks. I also mentioned how IBD recommended a $173.80 buy point (on high volume) based on a 3-weeks-tight pattern.
Anyway, I'll share a bit of the reasoning behind these technical terms. So, after a stock has made a big run (ie., TSLA going from $100 to $165), there's going to be inevitable profit-taking at various levels. What's happened over the past few weeks is that since TSLA reached the $165-ish level, there's been people cashing out (especially after the quick rise from $135 to $170). Usually what might happen is there would be downward pressure. However, with TSLA the stock held strong in a relatively tight channel (mostly 164-169). This is very bullish because this means that there were buyers who were holding up the stock and preventing the stock from trending downward with all the profit-taking. Typically, in this case it's not the retail buyers but rather it's the institutional buyers who would be providing this price support because the institutional buyers are larger in force. Know we don't know if it was a few or many institutional/big buyers providing this strong support, but that's irrelevant at this point.
When TSLA was quiet the past weeks, it's easy to assume that the uptrend has stopped and TSLA will remain consolidating. However, in TSLA's case this 3-4 week "rest period" is/was not a sign that TSLA has stopped moving up, but rather that it's pausing to let people profit-take and gaining a strong base for the next leg up.
There's a lot of talk going around about TSLA being overvalued and as a result the stock won't be going up that much in the near-term. However, I think this isn't accurate thinking. Sure, there's people who think TSLA is overvalued, but that's largely irrelevant to whether TSLA can keep rising or not. The reason being is people who think TSLA is overvalued typically just stand on the sidelines (or if they're super convicted, they're short). But the people who are largely responsible for the TSLA's continued uptrend are the buyers, and these buyers don't need to represent the larger media/analyst views on the stock. If there are enough passionate buyers of TSLA, then the stock has strong upward pressure. These buyers can be retail or institutional, but mostly institutional. So, really the question is if TSLA has enough institutional (and retail to an extent) support and enthusiasm to continue it's uptrend. Note, it doesn't take a ton of institutions. TSLA really just needs a few big ones to be passionate/committed and this provides a strong base of support.
So what the bullish flat base pattern (or three-weeks-tight pattern) showed was that institutional (or big buyer) support was strong and not letting the stock drop under $164 (or for not very long). In fact, at times the strong $164 support was quite remarkable.
At some point during the bullish flat base pattern (or three-weeks-tight pattern), the selling pressure starts to fade (volume shrinks) and it becomes more evident that the stock isn't going to go much lower. At this point (and maybe with the help of a catalyst like a PT upgrade by an analyst, etc), the stock starts to rise and people want to catch it before it keeps rising since they know there's a strong bottom base.
This is when the rising price action continues (usually with higher volume than the bullish flat base pattern period) and you see the upward price action.
So, today with the DB price target increase yesterday after hours, TSLA gapped up this morning and kept rising in the early morning. It took some time to break the $174-ish barrier but this is natural because it was a previous all-time high. When a stock reaches a previous ATH there's a lot of selling pressure as previous buyers get scared/anxious and think it's an opportunity to cash out or lock profits. Other buyers who bought at the ATH and were looking to recoup losses also try to cash out. But once the stock passes the ATH barrier, then there isn't that strong selling pressure at the price point so the stock can continue to move higher. That's what TSLA did after it broke through the $174 barrier.
It's typical to assume that TSLA will come down in price from here because it jumped from $166 to $177 in a day. However, the bullish flat base pattern provide a strong base for TSLA to continue it's run and to continue rising in price.
Also, with today's breakout into new ATHs, TSLA now attracts more traders as the stock starts to move again. Thus, I would expect to see decently high volume tomorrow and over the next few to several days as TSLA makes a lot of movement.
As TSLA moves up, the stock attracts both longs, shorts and scalpers. The longs don't want to miss out before it keeps rising. The shorts think it's even a better short at higher prices. And scalpers want to ride the volatility for a quick gain. All this means is that I'm expecting there to be volatility over the next several days.
I personally see a greater probability of the stock rising from here than falling. I'd say 70% chance it keeps rising into the 180s (and maybe 190s), and 30% chance it stays in the 170s or falls back to 160s.
I side with the stock continuing to rise because the stock has a lot of good signs. It's got a good base in the 160s that provides support for a push into the 180s and higher. It's broken out to new ATHs and that can attract new buyers (and shorts too). And there seems to be strong institutional support as well.
I do allot some chance (30%) for this breakout to stall in the 170s or to fall back, largely because I'm a bit wary of the overall market right now. If a large sell-off occurs (I have no strong leaning on when/if/how this might happen), then it could affect TSLA price support as institutions hold back on their purchases and even take some profits.
Overall though, I'm bullish on TSLA regarding it's short-term price action. And I'm even more bullish on it's long-term prospects. One of the great things about investing in TSLA is that you have access to real-time crowdsourced data (not just investor-related stuff but things like how demand is going and how people are liking/disliking the car and products). Most of TMC is not about the stock but rather the car, and it's a great way to keep pulse with the company and it's prospects.
Another great thing about TSLA is that it's a company/industry that easy to understand. It's not like some biotech company or enterprise software. It's a car company and it's easy to understand because we all drive cars and know all the major manufacturers. There is however the tech aspects of TSLA (ie., EVs, batteries, software, disruption, etc) that an investor needs to understand, but that can be gained through reading TMC and other places. Overall though I'd much rather put my money into something I can understand like cars than a company (ie., biotech) that I really don't get.
Finally, another great thing about investing in TSLA long-term is that TSLA is addressing such a huge market and it has 10-20 years of fast growth ahead of it. The auto market is a $1.5 trillion market, and is in the early stages of being disrupted by battery/electric cars. This disruption won't happen in a few years like smartphones, but rather will take 10-20 years because of the pace of change is much slower with autos than with phones. This can be an advantage to a TSLA investor because it provides some stability to the stock. In other words, it makes it into a long-term stock that can be held for many, many years. Sure, there will be ups and downs but as long as TSLA's long-term future looks great, then most investors can weather any storms by just holding the stock.
One final thought, I do agree that at some point TSLA needs to slow down (ie., act like other stocks). However, I still think TSLA's got a lot of volatility left in it (ie., high short interest) and that volatility will ultimately be in the up direction. I think there's a temptation to think or conclude that since TSLA has risen so much over the past several months that it's got to stop rising. However, stocks can do strange things, and the price isn't determined by what we feel comfortable with but rather what buyers are willing to pay. And people/institutions can pay very high prices for the rare companies that can demonstrate rapid revenue growth in huge addressable markets.
