Did Aramco Just Open Pandora’s Box? | OilPrice.com
Saudi Aramco is showing a little leg. I am a bit surprised that the earnings are as high as $111B. A moderate P/E ratio would place the market cap near $1.1T. I think the true reserve size is pretty much irrelevant to market valuation. It says that production volumes are sustainable for 5 decades, while the sustainability of earnings is very much dependent on oil prices. Also after discounting earnings, the size of the oil reserves is not the binding constraint the present value of earnings. Actually oil demand growth is the much more likely the binding constraint on the value of Aramco.
Additionally, the following gives us some clues:
So it appears that the Kingdom has tried to make the profitability look much more favorable by decreasing taxes. In that light the $111B is largely a manufactured number to so that it looks twice as profitable as Apple. If the tax rate were to return to 85%, what would have been $111B would shrink to $33.3B. So shareholder's EPS is still pretty much at the whim of the Kingdom.
The graduated royalties also look calibrated to make recent earnings history look favorable. The royalty is lowest while Brent is below $70/b and highest above $100/b. What impact could this have on oil prices going forward? I think the motive here for the Kingdom to reap more of the windfall from high oil prices, but what it produces is a progressive disincentive for grow all out when oil prices are highest. ROE for the shareholder does not increase linearly with the price of oil, but is sub-linear. Now as an alternative royalty scheme, a flat rate could be set to some level that would equalize the production cost difference between Aramco and US shale producers. The would created a financial disincentive for Aramco to try to undercut shale on price but not inhibit production growth when the price of oil is sufficiently high for shale to grow all out. I think a flat royalty structure would better align shareholder interest with a competitive market and help to stabilize and make less political the price of oil. The stabilization is improved because when the price of oil goes to close to the level of the royalty drilling stops and when the price is really high drilling is at a max. In this way, simple market prices can regulate production levels and not need much political intervention. But be contrast the progressive royalties encourage production when the price is low and inhibit production when the prices are higher. The interest of shareholders actually are more shielded from market price sensitivity, and so that could subject it to more need for political intervention just to balance the market, placing the interest of shareholders at odds with the kingdom.
As indicated in 2017, in preparation of the IPO, the Kingdom changed the income taxes Aramco pays to the government from 85 percent to 50 percent. The latter sounds reasonably positive, but the fact that the royalties on Aramco are progressive, wasn’t common knowledge. Shareholders will have to understand that the company’s effective royalty rate is determined based on a baseline marginal rate of 20 percent applied to Brent prices up to $70 per barrel, which increases to 40 percent applied to Brent prices above $70 per barrel and 50 percent applied to Brent prices above $100 per barrel.
