It's when you are further away from home that you'll find them useful.There's a new super charger going in 3 miles from my home, so any quick charges for long road trips would start there.
I did, for a year, and I'm not.Don't use a UMC at 40 amps, or you'll be sorry.
Because the mobile charge cables do get pretty hot at 40A, and heat is the main thing that degrades electronics and shortens their lives. @Edmond is trying to help you guys out. I'll use about 39 or 40 rarely if I'm on a trip and need the extra charging speed, but I (and many other owners) prefer not to subject their UMCs to that heat stress EVERY single day, wearing them out faster. Turning it down into the low/mid 30's amps, cuts the heat down a lot.please elaborate.
like another contributor I have charged my cars at 40 amps for a few years, what damages am I open to?
while he may be trying to help us out my experience doesn't jibe with the claims of doing damage to car or umc.Because the mobile charge cables do get pretty hot at 40A, and heat is the main thing that degrades electronics and shortens their lives. @Edmond is trying to help you guys out. I'll use about 39 or 40 rarely if I'm on a trip and need the extra charging speed, but I (and many other owners) prefer not to subject their UMCs to that heat stress EVERY single day, wearing them out faster. Turning it down into the low/mid 30's amps, cuts the heat down a lot.
That's because heat damage to electronics is not an instant thing, so you obviously won't just see it do damage in the first three years. It's the matter of something like shortening its life by a few years from a 10 or 15+ year time frame.while he may be trying to help us out my experience doesn't jibe with the claims of doing damage to car or umc.
I charge almost every night at 40 amps with my "portable" umc and have done so for 3+ years with no apparent problems.
in other words, like every other part it will suffer from wear and tear. thanks for the info.That's because heat damage to electronics is not an instant thing, so you obviously won't just see it do damage in the first three years. It's the matter of something like shortening its life by a few years from a 10 or 15+ year time frame.
I'll explain another aspect of this, which is materials' science. It's not just the heat itself. It's heat CHANGE. Materials get stressed and brittle when they go through a lot of cycles of far temperature differentials. When they get heated up a lot and then cooled down a lot, and back and forth many many times, the materials get fragile and get micro-cracks in them. When you are not using the equipment, it is sitting at room temperature. When you use it, you heat it up some amount. The farther you heat it up, getting it farther from room temperature, the bigger that daily swing in temperature is, and the more cumulative damage it is doing to the metals/welds/connections, etc.
I suspect this will change after you take a couple of road trips.
Heh, kind of. The point is that you can subject it to less wear to make the equipment last longer by letting it take an extra half hour overnight while you are sleeping, when that charging speed difference doesn't matter. So there is an upside without a downside in that.in other words, like every other part it will suffer from wear and tear. thanks for the info.
Certainly the newer UMCs are better than the older ones (many were replaced during the first year), but if I charge at 40 amps, parts of it get quite hot to the touch.The UMC is actually under-designed, in order to make it small and beautiful. It has compromises that the HPWC doesn't have. If you just look around here a little you will find lots of UMC failures, and without exception they charge at 40A or better.
And furthermore, I am not giving you an order. I am trying to give you reasoned advice based in fact. You don't have to take it, and you can even DisLike it as much as you want, but you do so at your own peril. No skin off my black arse.
