MrPlaidz
Very nice. What are the specs on the wheels (width and offset)?
2nd that!
Anyone else running Continental ExtremeContacts?
When I used to run Michelin Pilot 4S on the TEs on my old S, it sat lower all around than how my current setup sits. Wondering if it’s just how the sidewalls of the tires are compared to the Michelins.
Even at the lowest suspension setting, the wheel gap now bothers me.
Am running UP lowering brackets on both for reference
you can also do
20x10 et 35 285/35/30
20x12 et 32 325/30/20
Looking to run 21x10 and 21x11 rims on a 22 Plaid. Thinking of running 32 offset front and 37 offset rear. Thoughts? I’d like to get flush with fender if possible but fine being slightly in vs slightly out. Any help appreciated…
My favorite wheels on my favorite car in my favorite color!
Your offset also depends on your width. I assume you are referring to his 21x10 & 11, if so that might be close to flush. You'd have to double check the math a bit.I've been doing a lot of research on Plaid fitments too - it seems +10mm in front and +13mm in rear over OEM is flush on the Plaid. Anyone else feel free to chime in if you disagree. Your fitment is +14mm front and rear so you are pretty close to flush if not slightly "over flush"
Plaid fitment
front flush fitment with 21x10 et22
rears 21x12 et 32 not 21x11
Doesn’t seem right. Looking at mine, I think you’re right that fenders are around 103mm from the hubs (so 11” +36 is about flush…). 12” +32 Is over half an inch past that. I can’t see that fitting well without tucking them in with a ton of camber.So the rears would be pushed out 32mm over stock. That's flush!? pics?
Do you have any photos showing this fitment?Plaid fitment
This guy is running a similar offset in 20 inches with lowering links
285/35/20 fronts
335/30/20 rears
stock oem 21 plaid
21x9.5 et 40
21x10.5 et 45
Those wheels have really grown on me. I like em and the offset with the spacers look great.PLAID with theNewAero razors. 21“
Old „Raven“ wheel specs, plus 15mm spacers on front and 20mm on back to achieve the flushes of the actual (but basic IMHO) plaid Arachnids. For the time being until TNA offers Plaid dimensions. Heck maybe I even keep those on since I don’t plan on going 200mph anyway.
255 front, 275 rear
View attachment 757539View attachment 757541
Your wheel selection looks great - and your Porsche rival still beats all including the 918. Well done!The only wheels I found after a long search which evoke and symbolize the power of this Porsche rival by sheer looks. The Plaid needed something special. I used ultra strong spacers from Motorsport-tech.com as seen here in another thread. They are BTO. Thought it was a good idea with all this power and the 80$ more per pair is a reasonable investment. Sorry for the red brake dust all over. Time for Tesla to switch pad manufacturers.
Thank you! They’re 20x9.5 +22 / 20x10.5 +25 (if I remember correctly). Either that or the rears could be +30Those TE37s look great @Fatalblitz . What spec are they?
