Signature vs. GP nose cone
Discussion in 'Model S: Interior & Exterior' started by KBF, Dec 3, 2012.
  1. AnOutsider
    AnOutsider S532 # XS27
    Fwiw my sig has the rubbed cone, not the smooth one
  2. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    Dunno. Here's a pic with the panel removed. The red cover on the post shows the pos battery connection, but the battery is elsewhere. Please ignore Signature gaps and bugs.
  3. contaygious
    contaygious Active Member
    Marina, San Francisco
    FYI I asked about the nose cone change at the factory and was told it is for aesthetic reasons and they were surprised when it changed after sigs already shipped.
  4. artsci
    artsci Sponsor
    Timonium, Maryland
    Did you remove the panel yourself? I'm thinking that maybe that the all of the pieces of the nose cone snap into place as this piece does. If so, it will make installation of a number of things much easier. What do you think?
  5. roblab
    Yes, using a very dull butter knife. It just pops out with no effort. You can see where the clips seat.
    I think they did it for simplicity and cost (duh). I would think the whole nose would snap out and off easily. It gives access to things like frunk latch, wiring, etc. One piece is a lot cheaper than 3-5 pieces.
  6. dtich
    dtich #P708
    Los Angeles
    hey, little thought for threads like this: i find it incredibly helpful to know the prod seq # and vin (if avail) when discussing differing aspects of delivered models, for tracking production changes.. would be great if those of you who don't have your prod # and vin in your signature or member dets (on the left with avatar) could include such in your posts.. esp those with pics.
    thanks!
  7. FlasherZ
    Well, we compared mine with another local model S that had been delivered about 2 weeks earlier, and the nose cone is the same. So it appears the dividing line might be production vs. sig.
  8. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    Here is a comparison between the "old" nose, from one of Tesla's studio shots,
    and the "new" nose on my (as yet undelivered) Canadian Signature (VIN S02001):
    In addition to being aesthetically cleaner, the new nose should be aerodynamically cleaner, in a crucial spot-- the first part of the car to touch the wind.
  9. artsci
    artsci Sponsor
    Timonium, Maryland
    Thanks. Great to know. This means installation of the Passport radar detector and Blinder laser jammers will be much easier. I'm also thinking my EZPass transponder can attached under one of the upper nose cone plastic pieces.
  10. AnOutsider
    Makes you wonder why that change wasn't made sooner.
  11. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN P65513, Model 3 Res Holder
    Redwood Shores, CA
    The timing may have been supplier related.
    Also, isn't the chrome line all across (including the V under the T logo) more pronounced/wider than it was before?
  12. Vger
    Vger Active Member
    I noticed that also.
  13. brianman
    brianman Burrito Founder
    Generally I like the look of the new cone better, but I wish they had kept the "bent emblem". The new one looks it is flat rather than following the curvature.
  14. David-El
    David-El Model S - P3078
    Fremont, CA
    They probably didn't want anyone to confuse it with a Bentley... (cue groans)
  15. SCW-Greg
    SCW-Greg Active Member
    Beaverton, OR
    Just to add a more edge-on view of what's been posted already (Get Amped Series Sig)...
  16. Grendal
    Grendal Active Member
    Santa Fe, New Mexico
    It might be that this picture explains the reason for the change to the new nosecone. If Tesla had originally intended to have a grill for the two upper pieces but then later discovered that the extra ventilation was not needed then switched to solid pieces for more aerodynamics. Then finally they switched to the current one piece for simplicity and even greater aerodynamics.
  17. artsci
    artsci Sponsor
    Timonium, Maryland
    Courtesy of Tesla service, here's an exploded view of the nose cone parts. If someone with the car (mine won't be delivered until April or May, otherwise I'd do it now) can pry off the large lower piece and photograph what's behind it, that would be a great help for all of use who are wondering if we can install a toll transponder in the space behind the nose cone.
  18. NielsChr
    NielsChr Member
    Denmark
    the new one piece front cone looks more "burgler" proff - the one where you simply snap out a litle piece of plastic with a simple tool seams not safe - specifically if this gives you acess to shorten/discornect the 12 volt system and open the frunk latch.
    if someone needs access to the frunk, nothing will prevent them from gain access in less than 1 min. ....I do hope the frunk is equiped with some sort of alarm censor (I might be to worryed, so please ignore my posting)
    Models S is a fast performance car, I guess some young poeple would like to take it for a quick spin, better make it damm difficult for them to get into it.
  19. artsci
    artsci Sponsor
    Timonium, Maryland
    I think entries without the Fob will set off all kinds of fireworks.
  20. DaveVa
    DaveVa Sig Perf #236 VIN #484
    Northern Virginia
    Has anyone tried to put their EZPass transponder in this area of the nosecone?
