Was due for a survey and install today. Guy turned up at 8am then I walked him through where I wanted the unit and the routing into the house and under the stairs. They would need to drill into the house then run the cable under some trunking along the skirting ( about 2m) and under the stairs. We spoke about how to make this tidy as there is a change in skirting depth about 8 inches before the stairs - I said he could channel it out ( the 8 inch bit ) and I would make do myself after.
So, he then says he would need to speak to his boss as this was looking more like a days works. He then comes back and says this would have to be a survey day as he’d like to go away and think about it. He also made noises about there being a BT cable close to where he needed to drill into the house but I pointed out if he drilled an inch above it there was absolutely no way he could hit it.
I was not happy at this point. As far as I am concerned it would take an hour at the most to do the ‘difficult’ cable bit and then it should take no more than an hour for a competent electrician to do the work at either end. No way on earth was this a days worth and I’m not paying any more then I have to to people,who, in my opinion, are just looking to make an extra quick buck . I then told him to forget it as I’m not having them fitting it if that is their attitude to a very small amount of extra work ( if any).
So, Rolec off the list then.
