WannabeOwner
we'd need to buy more stuff
And a second dishwasher - to use as the cupboard for it
If you are getting through the night on battery easily then that sounds fine. I misread your O/P, sorry
I'm similar after a full month - £18.75 electricity (compared to £135 the month before) and gas cheaper as I moved some hot water heating to the immersion heater.first full month with the battery - £23.30. About £13 of that is the blooming standing charge so a tenner for the electric isn’t bad. 31kwh for 31 days so averages to a kwh per day. I still think thats a little high if most of it is ‘inverter lag’ but there will have been some spikes for high loads being on etc but only for a few minutes.
£50 for last month for me, including some over night charging from the start of may. Daily seeing costs of about 80p to £1 just now (60p standing charge), which is mostly what I would call arbitrage - the grid covering the 10s it takes the battery to ramp up to cover something like a kettle getting turned on. A second battery wouldn't help that, but a faster one would.I'm similar after a full month - £18.75 electricity (compared to £135 the month before) and gas cheaper as I moved some hot water heating to the immersion heater.
The diminishing returns of a second battery just don't stack up though. Maybe my £5 of actual electricity usage goes down to £2 - the rest would be taken from the grid no matter how much battery storage I had because a couple of rings on the hob and the oven on and you are well over what the inverter can supply. Then in winter my 4 hour cheap rate period isn't long enough to charge two batteries.
Yes, that's one of the differences/advantages of Powerwall vs GivEnergy. Your two Powerwalls charge in parallel, whereas the single GivEnergy hybrid inverter only provides 3.3 kW charge to the batteries which essentially charge in series.My 2x PowerWalls charge in under 4 hours (provided no other significant load in use - if so they throttle back to draw less power)
Obviously I could install a second inverter with the second battery but that is yet more expense that would be difficult to get any return on.
It’s 3.6kW charge rate per 5.0kW hybrid inverter isn’t it? (gen2 and Gen 3) - so two would give you 7.2kW nominal charge/ discharge(?) rate. Plus a bit extra for peak startup. Can fill them in under 5.5 hours on IO.
But maybe, as you say, it’s not viable for your set up?
This made me start thinking. I have one Powerwall 2 and have been keen to buy a second or third to take me longer off grid. Getting one at a sensible price is impossible....I may have died before it was actually delivered, lol. So I am thinking of getting rid of the Powerwall and installing a large libbi say a 20 or something similar from GivEnergy.Yes, that's one of the differences/advantages of Powerwall vs GivEnergy. Your two Powerwalls charge in parallel, whereas the single GivEnergy hybrid inverter only provides 3.3 kW charge to the batteries which essentially charge in series.
Mind you, there is only a 5 month lead-time on powerwalls at the moment but that might depend on who you ask. and to bare in mind that it will probably take a few weeks for your DNO application. I ordered in November and was told circa 12 months but am having it installed this week.This made me start thinking. I have one Powerwall 2 and have been keen to buy a second or third to take me longer off grid. Getting one at a sensible price is impossible....I may have died before it was actually delivered, lol. So I am thinking of getting rid of the Powerwall and installing a large libbi say a 20 or something similar from GivEnergy.
Does anyone know if there is a market for a 3 year old Powerwall?
And do Tesla commission and support it?Don't see why not, but would anyone (approved) install it?
I shall ask the question to my installer later this weekAnd do Tesla commission and support it?
Impossible to tell. Provided they've been commissioned, decommissioned, moved and recommissioned by approved installers I don't see why the warranty would necessarily be voided.I would think the new owner gets zero Warranty on it, which would be a shame...
Does much ever go wrong on them?I would think the new owner gets zero Warranty on it, which would be a shame...
They definitely allow transfer of warranty to a new owner but that's really for the scenario of a buying a house with it already installed. It will be interesting what Js1977 finds out.I would think the new owner gets zero Warranty on it, which would be a shame...
