Yep, I'm on Go too.
We have the battery set to charge up overnight at the cheap rate and also charge one of the cars (we have 2x EVs) overnight in the 4 hour window when needed. We charge the system battery to 100% every night but could do less as we have some surplus from solar on sunny days. My view is that it is so cheap to fill the battery anyway, little point in not doing so as we would risk using more peak rate electricity if it was a cloudy day. We also have timers on the washer, dryer and dishwasher so they only run during the cheap rate.
We do lose some surplus solar back to the grid on sunny days while the battery is at 100% and the house draw is too low. I've now got the info needed to set up an export tariff. Not rushed to do it though as its only about 4p a kWh and in reality wouldn't add up to too much anyway - I will get it done at some point.
We have toyed with the idea of trying to use the surplus to charge the cars but our charger (WallBox) doesn't have the sophistication needed to manage the surplus itself in the way some (Givvi) can. I have used the granny charger on really bright days when we have been pushing more than 2kWh back to the grid, but even that runs the risk of cloud cover or the odd boiled kettle meaning that we have some peak draw so we've abandoned that idea.
The Tesla Gateway disconnects the Grid from your house in the event of a power cut and puts you in Island Mode so your solar would still work with the PWs; you can simulate this with the Go Off Grid option, see pic. Your ability to do this will depend on the features of the system you bought.Our system goes in Monday 2 x 9.5 kwh batteries plus 1 inverter and 10 panels. How do I ensure in the event of a grid failure I still have power? do I need to do something special ?
Thanks
Good point. On our system, we use Time Based Control and when we had one PW, the PW didn’t always charge to 100% overnight in summer. But now with 2 PW it always charges to 100% so I can end with maybe 50% left before the GO cheap rate cuts in.Personally I think that it's easy to fall into the trap of over-thinking these things and adding too much complexity. I found myself falling into a deep, dark hole this morning looking at Pi servers for Home Assistant before I realised that spending a couple of hundred quid and hours of frustration learning and setting up a system to monitor PV output and automate routines was a fool's errand. The pennies saved will not recompense me for the hours of messing about.
As we are in Summer, I let the system charge the 8.2kW battery to 35% on overnight cheap rate power. That then sees the house through the night and the battery ends up at about 10-15% charge in the morning. I then let the PV charge the battery (on a good day its at 100% by 10:30AM). The solar diverter then puts the excess into heating the water cylinder. By then, again on a good day, its probably 1PM. If I am at home I then plug the car in and let the Andersen charger push the excess into the car. Again, on a good day, I can get maybe 10kW in there.
My PV system has generated 40Kw at peak in a day. Normally it's lower than this, but that gives an idea of what I'm playing with (May's total generation was 696kWh, June was 756kWh) . Getting the panels and battery in was the big jump. Everything after that is a game of diminishing returns.
9.5kWh batteries? A GivEnergy system?Our system goes in Monday 2 x 9.5 kwh batteries plus 1 inverter and 10 panels. How do I ensure in the event of a grid failure I still have power? do I need to do something special ?
Thanks
Yes indeed, I got a quote for a second PW just for interest and they said £9675!For orders not placed, I've heard extra PWs are now over £9k. Heard Tesla are managing demand with price.
I believe there are four options for the GivEnergy EPS. Option 3 which I've opted for, allows you to link your existing house electrics in full. However the system doesn't have auto fail-over and involves a simple manual switchover. I prefer this as it means I can check which appliances are running and that they don't overload the system. I have critical circuits (servers, CCTV etc) on UPS so that option works for me. Power cuts here are very infrequent but I've gone belt and braces as the future energy landscape looks a bit dodgy.9.5kWh batteries? A GivEnergy system?
If so, then you need the sparky to wire in the EPS. All connected circuits will need to be totally separate from the existing consumer unit, including earthing. This is to ensure that the batteries do not feed current into the grid and fry a poor line worker somewhere.
Do you get frequent power cuts?
The thing is if enough people on a street submit 3.68kw notifications, whether they end up installing it or not, the DNO can't refuse these by law and the cost of any infrastructure upgrade falls to the DNO. Just saying...
Not quite sure I know what you mean here - if its the smart energy meter display thing it's next to useless and we have it plugged in but rarely look at it.How does it work with your in-house display? Does it correctly show usage adjusted to what the panels are putting in or does it become useless?
And for those on FIT does the price move in reverse?
All the details are here:I believe there are four options for the GivEnergy EPS. Option 3 which I've opted for, allows you to link your existing house electrics in full. However the system doesn't have auto fail-over and involves a simple manual switchover. I prefer this as it means I can check which appliances are running and that they don't overload the system. I have critical circuits (servers, CCTV etc) on UPS so that option works for me. Power cuts here are very infrequent but I've gone belt and braces as the future energy landscape looks a bit dodgy.
I'd contact the installer asap. My outfit are planning to send a sparky a day ahead of the main install as the EPS is not trivial apparently. There will be additional gear needed too.Same here, trying to belt and braces in the event we get power cuts this winter, will ask the sparky on Monday for option 3, happy for it to be manual but would prefer it to cover whole house ccts, hopefully not too much extra work at the time of install.
All systems are givenergy, battery and inverter
Thanks for the tips all
Same here, trying to belt and braces in the event we get power cuts this winter...
Wise choice; we will have up to 40kWh of energy stored with a max 10kW discharge and the capability to charge our two EVs with with either of our two 7kW chargers or a granny charger. We have not used the grid between 4:30am to 12:30am (20 hours) for many weeks now.I've done the belt and braces as well.
Solar Array feeding two Powerwalls, Tesla Gateway powering 7kW ev charger (Grid tied) and 7kW Commando ev charger (Backup side), plus 22kW ev charger on 3 Phase supply (Grid tied).
Dual fuel central heating (gas or electric), and dual fuel water heating (gas or electric).
Took me a while to sort it all out, but I'm now ready...
I generally take alarmist media bites with a significant amount of salt…Re powercuts:
Six million homes could face winter power cuts due to energy shortages - report
Under plans drawn up by ministers, electricity could have to be rationed for up to six million homes at the start of next year, mostly at peaks in the morning and evening.news.sky.com
I'd rather be safe than sorry.
