I hope that is the problem. Tesla is supposedly looking into it.Looks like you are seeing 1 of 3 inverters. Tesla will need to fix it for you.
3 inverters. I don't think it's mis-reporting as powerwall is filling up at the same rate.
Are there any tools to dig in deeper than the tesla app?
I don't think it's misreporting as it's filling up the powerwalls at the same rate as the generation.Definitely could be even more - was probably being a bit conservative, but basing it on the time of year and having a solar glass roof with similar layout (mine being 50/50 north/south) and the larger size (and, though thousands of miles away, similar latitude) and the data I've seen for our system. In any case, 30 is clearly low, and though I don't know the local smoke conditions (and possibly soot or other dirt on the tiles) it seems rather unlikely it would cut production so much.
Hopefully it does end up being something simple like turning on/rebooting an inverter.
To investigate the possibility of an inverter not properly reporting, it should be possible to compare production numbers in the Tesla app to what shows on the meter (or on the utility's website.) If they are way off (with the meter/utility showing much more solar generation) this could indicate things are working but an inverter is just not properly reporting its data to the app.
Spa but no pool. I have cars to recharge, though the mileage has dramatically dropped. I'm planning to replace our HVAC with an all electric unit. Ditto with the water heater and stove top.on another note 25MWh for the year is a lot of power. Hope OP can use it all otherwise they sold you too big a system
Probably has a big pool
Is there a way to determine if all three inverters are working?
Apologies for having started this in the rooftop layout thread, but I hope there might be some suggestions from the broader community. We just turned on our solar glass roof with three powerwalls. Expected generation to the some reasonable portion of the 21+ kW spec'd. We are seeing peak generation of less than 7 kW.
I haven't completely freaked out yet because of the smoke, and would expect some drop in production. However, this seems to be more than I would have expected.
I assume the Tesla contract numbers reflect the orientation of the roof and surroundings. They were:
One 365th of the annual 25,259 kWh would have an average daily production of about 70 kWh. One would expect August to be higher than the average, even with the smoke. We're seeing around 25 kWh to 39 kWh.
- Solar Roof system size: 21.98472 kW DC
- Estimated gross annual electricity production in kilowatt-hours (kWh) from your Solar Roof in Year 1: 25,259 kWh
Any suggestions?
You can add to SGv3, later, it will just be very expensive.If you have a solar roof then the solar capacity of the roof can’t be expanded later. If you have panels you can always add more panels, but it’s really more like just adding a second system rather than adding panels to your existing system. But as long as you have roof space left you could add another system with more panels and another inverter to supplement the original system.
They are labeled as teslaWhat type of inverters do you have? Do they have screens or lights? What’s on the screen or which lights are on for each of the inverters?
I don't know the vendor Tesla is using for the inverters, but I attached a photo. The solar LED is on most of the time and the lightening bolt blink irregularly.Do you have Solaredge inverters? I have their app setup and it gives details on how much each panel is producing for the day (also week, month, etc). Perhaps it can shed more light into why production is low.
I don't know the vendor Tesla is using for the inverters, but I attached a photo in a prior post. The solar LED is on most of the time and the lightening bolt blink irregularly.What type of inverters do you have? Do they have screens or lights? What’s on the screen or which lights are on for each of the inverters?
That is a Delta M series inverter.They are labeled as tesla
One at a time I shut down two of the 3 inverters. Each time the reported generation dropped by about 2kW of the system's total 6+ kW.
Not looking good...
I didn't think of my system in MWh until now. 18.7MWh sounds like a lot more production than 18,700kWh.
In 64 years when I hit 1.21GWh produced, I'm going to have a huge Back to the Future party I'll also be nearly celebrating my 110th birthday so it might not happen.
Several reasons for not getting the most out of your peak panel production and daily production:I'm only a few days running and starting to take a look at my charts and searched the forum to land on this thread. Had similar questions on production.
I'm on 12.24 system on SolarEdge 11.4 inverter. While it's been less than ideal in Houston, I'm seeing afternoon production spikes in between 11ish kWH fairly consistently during the peak 1-2 hours. If I take raw math, I think my system is "efficient", but what's the real limiting device? Is it the inverter or actual panels? Panel math 340 wtt x 36 panels = 12.24 kWH and I'm getting fairly close to the panel specs but thinking maybe it's my inverter. Thoughts?
