Damn. And I thought Tesla's pricing recently was aggressive.
thats AUD, convert to USD at your leisure.
... going by your graphs 'STC's are ~ kWh/watt production at STC
No, you use it as a unit equal to one kWh/watt annual production at STC conditions.to be more precise, we use STC as a stand in for (lifetime kWh) production.
Yes, I understand. There was a thought behind the STC label appropriation. It appears to be an attempt to generalize the idea of displacing fossil energy. When it comes to PV, if a kW array produces 1 MWh per year at STC conditions it is called a "1 STC" system.1 MWh of renewable electricity generated by a small generation unit...'
LOL !renewable energy certificate - STCs Small-scale technology certificates ~ 1 MWh of PV.
I didn't get that right. I should have saidWhen it comes to PV, if a kW array produces 1 MWh per year at STC conditions it is called a "1 STC" system.
The NM PUC rejected PNM's recc for NG+PV“Some of it is policy-driven, we have the Energy Transition Act, but I have to believe that most of it is market-driven. These are deals that are from $18-25 per MWh – that’s cheap electricity. it’s a business decision as much as anything. They’re a regulated utility that must be responsive to its rate base. This is one way it gets there.”
I think the vertical panels maximize agriculture. They use bifacial panels to minimize solar loss from vertical mount.What are the advantages to vertical panels? Less space required between racks? Easier to mow inbetween?
From a layperson's perspective, it doesn't seem like the benefits outweigh the production lost by pointing the panels at an optimal angle.
I'm installing a new array. Faces South West. Should have good afternoon production.As panels prices keep falling and mid-day solar production increasingly saturates the grid I expect that we'll see more and more vertically mounted solar. The 'optimum' angle is going to be what captures the most energy just before sunset which is ~vertical.
