The first problem is voltage. Solar cells are 0.5 apiece. So 30 or so will charge your 12 volt accessory battery. In order to charge the 375 volt battery pack you would either need 750 solar cells, or DC voltage step up electronics. The second is wattage, which has been addressed above. So no range increase.
If you want to negate vampire drain, put a small solar panel in the window, connected to the acc circuit. (Does the Tesla shut off the 12v outlet when the car is off?) Price: $50 at most.
Thank you kindly.
