Latest Thesis
Here is the thesis that will affect what I will do with 8,000 shares. I request people here to correct me if I am going wrong anywhere. I have no agenda but to figure out for myself what to do with the position that is painfully underwater.
A note on Net Relative Value (NRV)
By now it is very well established that NRV and the trajectory of NRV is the most important valuation tool wrt SCTY. Probably this is the only tool available.
None of the traditional financial metrics apply properly to SolarCity's Business model. This is widely established.
In addition, the newer Equity Value Creation (EVC) metric released by SolarCity looks too theoretical for me to trust too much. See past few pages in this thread to get a sense for it.
The few analyst reports I have read in the past directly referred to Retained Value for valuation and valuation projections.
Impact of ITC step down:
My understanding is that SolarCity prices their systems at around $5/W. As ITC goes down from 30% to 10%, that will have an impact of about $1/W.
Unfortunately SolarCity cannot merely pass it on to consumers as they are ultimately limited by utility rates on a Cents/kWh basis. If SolarCity prices higher, consumers will simply not choose to get a system.
So this $1/W needs to be overcome somewhere on the cost side or else it will run into lowering (or even creating a negative) incremental NRV.
Management discussion of ITC step down
In Q2 call ITC impact was discussed to some degree. Here are the snippets:
Brad Buss: "Applying the expected impact of a 10% ITC in 2017 with our 2017 cost goal, we would still maintain healthy unlevered IRRs of approximately 7.5% and an equity NPV of roughly $0.60 per watt."
Lyndon Rive: "We believe that our cost structure will allow us to thrive post-ITC reduction and generate $0.60 per watt for equity value"
Lyndon Rive: "for most of the projects that we were deploying, we will continue to just install and have a $0.60 per watt economic value creation instead of over $1 but, yes, we'll just continue."
Lyndon Rive: "It's a combination of cost reduction and less cash going to the (01:00:58) investors. That gets us to the $0.60 a watt."
Now here is the real kicker. All of the above snippets relate to EVC and NOT NRV. To know that for sure you would have to read the whole of Bard Buss comment. Here it is:
"Economic value creation is a key metric we introduced last quarter, and it captures the total value creation to equity using our actual Q2 installs and cost for the forecast for debt. Our EVC increased 33% from Q1, driven mostly by deployment growth and lower cost. The Q2 unlevered IRR was 12%, up nicely from 11% in Q1. The NPV on a per-watt basis was approximately $1.14 per watt, suggesting a range of approximately $1 billion-plus of annualized equity value creation in 2015 based on our megawatt guidance.
If we run this very same model applying the expected impact of a 10% ITC in 2017 with our 2017 cost goal, we would still maintain healthy unlevered IRRs of approximately 7.5% and an equity NPV of roughly $0.60 per watt."
In a nutshell if you are looking to put valuation on SCTY through NRV and trajectory of NRV, unfortunately, all of this commentary is not relevant.
That leaves the problem of figuring out NRV trajectory to ourselves.
Current state of incremental NRV
NRV is based on bookings. We only have NRV data from Q1 2015. So we can assess the incremental NRV for only two quarters.
Q2
Bookings: 395 MW
Incremental NRV: 3057 - 2718 = $339 mln
Incremental NRV/W: 339/395 = $0.86/W
Q3
Bookings: 345 MW
Incremental NRV: 3256 - 3057 = $199 mln
Incremental NRV/W: 199/345 = $0.58/W
Q2 + Q3
Bookings: 395 + 345 = 740 MW
Incremental NRV: 3256 - 2718 = $538 mln
Incremental NRV/W: 538/740 = $0.73/W
Impact of ITC stepdown on Incremental NRV
As discussed earlier, ITC step down causes a reduction of about $1/W revenues. On the other hand shareholders are currently only getting $0.73/W.
So as you see now, IF costs were to remain the same, with ITC step down, incremental NRV will be NEGATIVE $0.27/W.
In other words, for every new install, shareholders will be losing additional money off of existing NRV!
Cost Savings in preperation of ITC step down
Obviously the team is working very hard to lower costs. Let’s take 'their' guidance on cost reductions.
As per the latest deck, the targeted savings are $0.34/W. See page 5.
It doesn't appear that Silevo panels are included in these savings. Guidance on Silevo panel savings is $0.25/W. This is from the latest CC: Tanguy Serra: "The number that I have been using is relative to today's costs and it's about a $0.25 [a watt of panel]"
Note though these panel savings will not affect all installations. Because production is going to be 1GW in 2017 but installs are going to be more than 1.25GW. So just prorating a bit, let’s call the savings to be $0.20/W.
These are projected/targeted savings. Nobody has a crystal ball. But lets be optimistic and use the number as it is.
So we seem to have potential aggregate savings of about $0.54/W (0.34 + 0.20).
Now lets look at the potential Incremental NRV
ITC step down impact: $1/W
Potential savings: $0.54/W
Impact on Inc NRV:0.54 - 1 = -$0.46/W
Current Inc NRV: $0.73/W
Inc NRV after ITC step down: 0.73 - 0.46 = $0.27/W.
Conclusion
Incremental NRV will be $0.27/W if all goes as planned.
This is so razor thin, that if you discount away some of the renewal RV, you might as well hit 0.
Keep in mind we didn't even touch net-metering dilutions here. Any dilution will effectively cause SolarCity to pull back from the state or operate on losses. Then what's the point. The more they install, the bigger the losses will be.
Tesla batteries are of no help. Infact they hurt. Because SolarCity will now have to bear the costs of the batteries while still keeping the price per kWh the same. So no revenue, only cost.
In summary NRV will remain flat or worse start trending down starting 2017.
As per my previous post
here, the projected NRV/Share at end of 2017 is $41. Effectively $41 is the max the share price will go for foreseeable future (several more years).
Unless SolarCity's business model fundamentally changes, I really see no solution here. The business model is broken. It will not work.
To me it feels like management is using all sorts of accounting gimmickry to come up with brand new metrics like EVC to hide the facts. Come 2017 Q1 ER, there is a good chance that NRV will reverse trend (say if the Buffalo factory doesn’t start on time, or is not as cost effective as hoped). Management might cleverly try to hide the slide and say we no longer publish NRV because we don't internally track the Business that way. In that case investment community will be left with 'nothing' to put a value on the shares. The stock will plummet either ways.
P.S
How come I haven't done this analysis before. How did I go so wrong as to the extent of buying a whopping 8000 shares?? I have been thinking about this myself. Will post a post-mortem here once I have final thoughts. But of course, I need to make sure, my latest thinking is in fact correct before I pull the trigger and sell at losses.
P.P.S
I'm happy to send a screenshot of my account statement to any doubters.
- - - Updated - - -
Based on above you can easily conclude that current price around $30 is actually a very valid price. Scary to say.
