Correct - this was a first time - (one time by the look) booster.I think you’re confusing the two launches. This one was a brand new booster.
I'm also going to roll with Han's call on this one.... Bada BingYeah, language is not so precise, but general public would not understand the X,Y, Z coordinate systems/ axis.
In this case it was rotating around the long axis. So that would be roll.
Great footage to appreciate the size of those grid fins with a person climbing around for scale...Recovery Operations:
Warning, it's noisy.
NASA isn’t trusting certified pre-flown boosters. So only new ones for ISS/CRS missions.
Well a half orbit delay due to ground station issues will slow things down.I don't know if anyone watched the three and a half hour video of the Dragon capture. Wow. Talk about boring. If you aren't an absolute space enthusiast, it would put you to sleep. It's this type of boring stuff that killed the Apollo program. I hope SpaceX comes up with something to make this more exciting quickly. Certainly launches and landings are very exciting but a couple hours of time to latch onto the station then open a hatch is going to need something more.
The new Dragon (crew and then cargo) will dock vs berth and so will be much faster.
Plus it looks like they used 5 flotation devices on each side to help lift the tail, also to prevent rolling over while being towed.I'm guessing that strap show the center of gravity (mass center?) for the booster...
Makes sense, only way to set it down horizontally is to stow or remove the bottom leg.Leg- I think some one said it over the marine radio, that it was removed by divers. Look too clean to been shear off.
It's not just the speed. It's the fact that it is pretty mundane stuff. It's a bit like trying to make someone washing, drying , then folding their clothes interesting and exciting. It can be done but it needs someone with an artistic sense of drama to make it dramatic.
I saw the whole 12 minute video. Am I crazy?Video of B1050 being towed into port:
Normally 4, but this booster may have lost the bottom one on water impact.I saw the whole 12 minute video. Am I crazy?
Also I always thought it had only 3 grid fins, but no there is actually 4 !. There is one (presumably) on the side under the water line.
Same as always and always been there*. Tank is directly below, so can't mount lower. Interstate used to be white and fins used to be painted aluminum though.Am I having a brain fart? Were grid fins always attached to the interstage? I seem to recall that they used to be much lower down on the first stage. Also, did all the early attempts at booster recovery have grid fins or were they added later?
