It will be cheaper to charge.
It will be quicker to charge.
It allows a smaller battery and pack for a given range. This means less cost, lighter weight, better handling, smaller tires needed, better acceleration, smaller brakes needed.. Basically saving weight is extremely desirable in a car. Often times automotive engineers search desperately to save a few grams of weight here and there.
Edit: I just realized some of my points are oversimplified. You can either extract more range from the same battery size, or use a smaller battery for the same range.
A smaller battery may reduce the rate at which you can charge in kilowatts, but since you are gaining more ranger per kWh this would be offset. Also, lighter weight aids acceleration, but the power does come from the battery so a smaller battery may hurt acceleration if it is the limiting factor.
