Is there such a thing as a device you connect to 120 volt and it charges up and then when you connect it, it fast charges your car at 440 volts or 240 if that's the max it can do. Not sure how much voltage the Model 3 can take.
Only if off the other lug which makes it the same as using both lugs for any 240V in a home (US) except at a lower current (about 12 to 15Amps).There are devices that you can take two separate 120V circuits and combine them into one. I believe Ben Sullins did a video on one of them and it worked. You are still better off just having a new outlet installed.
A VERY long time ago, I used to set up lasers at dances. They required finding outlets that were on separate lugs and running extension cords to meet at the combiner. Fun times.Only if off the other lug which makes it the same as using both lugs for any 240V in a home (US) except at a lower current (about 12 to 15Amps).
A 35kWh (about ½ a charge) pack would probably weigh over 500 lbs and cost almost $5,000. You would need a motorized cart and this would add to the cost. Don't see ANYWAY this could be an option.....I suppose it could make sense for people living in apartments who literally can’t get an outlet installed where they park. Maybe a battery pack in a cart they could wheel inside and plug in to a 120 outlet (or even better, a 240 dryer outlet). Then when they get home they wheel the battery pack out and plug in to the car. No idea what it would cost to have enough storage to make it worthwhile, and the more expensive it gets the more you run into issues with securing the pack against theft.
Plus the electric field dissipates quickly so they would only be good for very short term power storage.Capacitors have much, much worse gravimetric and volumetric energy density. Plus they tend to cost several orders of magnitude more....
Capacitors have much, much worse gravimetric and volumetric energy density. Plus they tend to cost several orders of magnitude more. To be able to fully charge a long range car, you'd need somewhere around 80-85kWh minimum. At 6wh/kg, this would weigh in around 1,000,000 lbs not including an enclosure. The costs of such a system would be absolutely staggering.
So you're saying we have a chance....hold my beer.
I'd love to see a capacitor based storage system of that magnitude. Unless you're a very large government organization making a rail gun to go on an aircraft carrier, it's probably not happening.
Just a guess, but I bet they have a budget a little higher than some dude trying to save a buck by not running $50 in romex.
