Also, the release notes mention that it is currently only for local roads, so it isn't supposed to be working on freeways/highways.
Yep, mine totally ignores the freeway signs.Also, the release notes mention that it is currently only for local roads, so it isn't supposed to be working on freeways/highways.
The speed limit sign feature is cool, and works well on the standard white signs.
Here are some examples where my M3 did not see the sign at all
- Electronic displays
- Yellow (off-ramp) signs
No need to be. I asked the same question when it first came out as I had noticed it ignored the freeway completely.Ok, got it... so user error on my part... sorry![]()
How about speed limit signs on orange diamond shaped construction signs? I assume those wouldn't work either? It would be great if it did because otherwise the car will assume the usual speed limit still applies.
I’ve had to explain that to my wife numerous times. She has never cared and tries to use it against me for “speeding”.Yellow signs like the posted one aren’t speed limits so the car should never pay attention to those to begin with regardless of the scenario. Those are speed advisories for upcoming turns and such so that you keep your lateral g force under 0.22 Gs. If you were to have an accident on one of these curves going faster than this it could be used against you, but it isn’t an actual speed limit.
I guess this can't be totally true. For my recent road trip, AP displayed 75mph speed limit multiple times. I was mostly following traffic traveling roughly 9mph over. This is for I35 in Texas. v2020.36.10.
Unfortunate, since this is exactly when we need this feature to help reduce phantom braking occurences.
Phantom braking is not due to wrong sped limits. It is usually due to "seeing" obstacles in your path.
Are you seeing speed signs in the display similar to the way stop signs are displayed ? Our 3 took a few days before it started seeing speed signs.Is anyone's car not setting the speed limit based on normal, white speed limit signs on local roads? There's two places in my commute where the actual speed limit is very different from what the car thinks it is (Actual: 55, Tesla: 35 in one location, Actual: 65, Tesla: 45 in another). I was excited for this update to fix that, but it hasn't. There is a clearly visible white sign for both of these instances.
