Mark-R
In fitted a onestopnumberplate stick-on plate on the front of my M3 back in April and it is holding up very well. Still stuck on very well including around all of the edges.
You should post your question in the The UK and Ireland regional section.
Also, I saw this thread: Front Registration Plate (quick release or static plate) UK
As long as it meets DVLA requirements it’s fine. It doesn’t have to have Tesla / whatever on it - that’s just free advertising for themLooking to get some vinyl stick on number plates for the front and rear, but confused about the requirements on them.
Apart from being DVLA BSAU certified, do they have to show the manufacture at the bottom? (Teslamotors/Tesla)
the front bumper where you would put the plate is plastic so no rust. I also don't get the "shave" and "sand" ref I just deburred the existing holes. not sure if I filled them with a bit of epoxy putty or not, then just stuck a vinyl plat straight onto the bumper. 18months later no issues.Apologies for unearthing an old thread - I'm keen to remove and replace the plates on my imminent M3 and was going to attach to the 'underplate' shown further up on the front rather than starting to shave/sand bodywork for a vinyl one (its a lease car) My question is, if I decide to go the vinyl route, whether or not it is sensible to not fill the holes (rust?!), cover with tape and then re-insert the original fittings come end of lease?
Was happy enough just using the under mount but my private reg is 6 characters and was looking into getting smaller plates and the mount would be wider than the plate, so investigating vinyl, unless someone knows of a shorter mount where I could re-use holes and no, I don't fancy shortening the existing one
...or wouldn't I? Just thought that there must be a load knocking around that I could buy come end of lease and I could hack mine in the meantime...
Cheers Jason. Yes, the back looks infinitely more straightforward than the frontthe front bumper where you would put the plate is plastic so no rust. I also don't get the "shave" and "sand" ref I just deburred the existing holes. not sure if I filled them with a bit of epoxy putty or not, then just stuck a vinyl plat straight onto the bumper. 18months later no issues.
The back is not very flat under the plate holder so vinyl does not work as well. I just bought a standard plate and stuck it on with 3M padded tape.
Looks great and nothing that could not be undone if needed
I bought it from a company in Canada. Ron is the proprietor and he’s been great to wo with. Not sure how it work with plates from another country.I have a stick on front plate on my Model 3. Looks great, and can be removed easily with some hot water.
On No.3 - unlike the back, it is straight forward to remove the plate holder and just stick the plate straight onI've just read 14 pages of this thread and admired many photos....
Conclusions....
1. the stock plate holders are ugly and there are better alternatives.
2. the front plate can easily be replaced by a stick on plate
3. the rear plate holder makes this harder, but a simple unframed plastic plate screwed to the Tesla Mounting box will look better than the OEM box.
4. the Plod don't really care, as long as the ANPR cameras can read the plate.
5. based on the way Alfa Romeo fit plates to the N/S you could do that on the front...
6. As of 2021 there is no need to have a blue EU/GB strip, and the green strip as used by Tesla is optional, but if you go to the EU then a traditional GB plate is required.
When I put my personal/vanity plates on the car the Tesla "boxes" will go in the bin....
They areUPDATE:
My old, magnetic GB Plate sticks perfectly to the boot lid and wings of the M3. It doesn't stick to the doors or bonnet: I assume they are aluminium....
You only need to put a GB sticker on the rear of the car when travelling in Europe.They are
Well done for having the patience to read 14 pagesI've just read 14 pages of this thread and admired many photos....
Conclusions....
