Ahh .. now I am following you. It would be a poor idea to run a series of heat pumps.
People in the SE United states put DHW heat pumps inside the house because they get "free" cooling and dehumidication (a HUGE benefit) during their mostly too hot climate. They pay with noise.
I'm pretty sure Escondido should place the heat pump in the garage.
I've wondered before whether it makes sense to place the heat pump in a place that with vents and some pipes could have intake and outflow vary between inside and outside depending on season. Maybe in a home designed that way. The same could be said for the fridge ... which is also a heat pump. My rather crude calculations for a fridge in my overall winter climate suggested at least a 50% energy savings if it was paired with a heat sink and good insulation. About 0.5 kWh/day consumption for a 22 ft^3 fridge/freezer.
Integrated house thermal management system?
One smart high efficiency heat pump that provides high and low temperature sources for hot water, built in fridge/freezer, and HVAC, taking maximum advantage of ambient temperature and maybe even thermal storage?
Interesting in principle; I'm not sure how viable it'll be in practice. Presumably a lot of pipes to insulate...
