Clearly someone who hasn't read the thread and isn't aware of the facts.
By all means, don't elaborate.
The 'examination' was via software not by physical inspection.
YOU can be happy with 20%.. Enjoy it. We are ARTIFICIALLY capped, not DEGRADED. We are NOT happy with it at all.
That could be true. It could also just be a random charging session difference. Have multiple people confirmed this without any denials of it?
Just from (Google) translating that thread, I see the comment in which that graph was posted reads "OK last week, the battery was warm but the curve before the update was slightly better than now with the 28er straight to the end."
Your translation is correct, but that doesn't explain the higher tapering at 80% and above. At this SoC, the cells should have reached the same temperature in both charging sessions.
Nevertheless, more feedback would certainly be helpful.
Affected cars don't charge cells to 4.2V but 4.07V. No matter how much degradation there is, cells are always able to charge to 4.2V. Tesla limited this.By all means, don't elaborate.
It shows, that Tesla put artificial limit to battery.You say that like that's supposed to be a shock, or like it's supposed to change anything that I wrote.
Aren't they defective then?
When for years cells were charged to 4.2V and then one day they are charged to 4.07V, this is not somethig, that was done from day 1 of vehicle ownership.Yes, that's what a BMS does, from day 1 of vehicle ownership. That's the very reason why the BMS exists - to impose artificial limits on the battery, for safety and longevity reasons.
I'm not affected. But it is not relevant.Would you rather the BMS not do its job?
If you want the BMS to do its job, do you not want it doing its job as well as possible, based on the best information available, including that accumulated after the first software release?
If information arrives later that the earlier version of the BMS should have been doing something different than it was initially programmed to be doing, do you not want it being updated to do what it should have been doing?
I'm sorry that you got bad luck with a battery whose longevity turned out to not be as good as some others. I really am. These were Tesla's first batteries with silicon in the anodes, and it became clear as soon as they started having to impose higher limitations on supercharging rates that their longevity was not holding up as well as Tesla anticipated. But the solution to the physical reactions taking place in the battery not being as good as hoped isn't "screw the BMS".
Maybe, however, you instead do want to say screw the BMS? Perhaps then Tesla should add a button, "Please tell my BMS to let me destroy my battery pack at an accelerated rate, and flag my vehicle to all potential buyers that I did this so that they know should I choose to tell it on the used market; I hereby acknowledge that I'm throwing safety and degradation to the wind"? Would that make you happy?
Their statement to Electrek directly contradicts what WK057 has said
He said that both X and Z would need to be physically fixed eventually. He even said it was important enough that people that haven't updated should despite the negative side effects.
Tesla has shipped defective batteries to some customers and obvious solution is to replace those batteries with new ones which are not defective. Batteries are under warranty.
I have told my local Service Centre I don't want money, or a new battery, I just want the restriction lifted on my old battery. I would have thought that must be almost a cost free option. But their resistance remains robust. And as their answers are invariably taken from a pre-prepared statement, not always directly relevant to my case, I do wonder if Tesla has issued a 'reject all claims' policy.Agree there are many ways Tesla could and should provide some sort of good will compensation to the affected users. A replacement battery for everyone though is probably not going to happen regardless of any trial outcome.
Reports in the UK suggest the latest updates show 'some' recovery, a little more back each time. But I don’t want some of it back, I want all of it back. I remember I was asked to pay for all of it when I bought it.Interestingly, Tesla replied to Fred from Electrek.
They told him that new releases will fix this range issue. That sure seems like Tesla still believes the batteries are fine. It was a bug. Not Lithium dendrites or lithium plating.
I have an update from last night. Let's see how much capacity (range) comes back over the next 2 weeks.
Now on 2019.18.2
