I've installed the latest update 2019.28.2 and NO range has been recovered. My 90% SOC shows 207 miles of range when prior to #batterygate it used to show 234 at 90% SOC.
Not only that but the charge profile has also changed so that supercharging is now slower.
So far from improving things for affected owners, I believe that things have actually got worse.
Here is a supercharger graph taken after the latest update
Here is a comparison between a previous version and the latest Supercharger sessions
In the charge carried out with 2019.16.2, it took 41 minutes to add 47KWH @17C ambient
In the latest charge carried out with 2019.28.2 it took 46 minutes to add 43KWH @23C ambient
In both cases the car was driven for 25+ minutes before charging and the supercharger was selected in the nav to pre-condition that battery for best charge.
My feeling is that the new version is limiting charging rate more than the previous version - I was on an empty Supercharger pair, and that the fan runs much harder and longer (maybe 15 minutes) after coming off the charger at 90% SOC.
My advice if I was to give any would be to skip update 2019.28.2 if you can because it has only made things worse for me.
