Tesla (Panasonic) and GM (LG Chem) cells differ, though
That's it? What happened to the rest of your sentence?
Seems to me, that since this comes from an official channel, it could be used as evidence to further bolster our case.Many posts on this thread on coolant pumps running near 80% SoC. Here is the confirmation by Tesla:
Continuous Faint Humming Noise When Parked
"When battery pack reaches above 80% or close to and vehicle are parked and locked, 1 of the coolant pumps will be idling due to safety reasons and to preserve the battery pack. This are recently implemented in a firmware update."
A recall statement "Update to 2019.16 or later" is all they ever needed to do.
I realize that this thread would not exist if Tesla had no OTAs... They would have had to issue a recall to bring our cars in to the SC and explain why. We probably would have received replacement packs by now.
Yep, this will be the last car I own, that the manufacturer can mess with, without my permission.
did he mean new or old 80%?Many posts on this thread on coolant pumps running near 80% SoC. Here is the confirmation by Tesla:
The rest of the sentence is open to imagination. It might spark thoughts in a direction like this: Tesla has cells made by Panasonic in the same building and, I assume, knows most details of those cells. And can answer all NHTSA questions as detailed as needed. GM on the other hand buys off the shelf cells that, hopefully, comply with some GM requirements. So GM might not be able to answer NHTSA questions with the same level of detail as Tesla. And LG Chem cells were/are subject to recalls all over the world.That's it? What happened to the rest of your sentence?![]()
Good luck with that. Seems like that's impossible as long as things keep progressing in the direction they're going (Internet ofSh...... er, Things).
to monitor temperatures for anomalous readings as part of the "enhanced diagnostics" if a cell is heating up beyond safe limits a module can see it by temperature being consistently higher leaving that module
Tesla isn't trying to replace dangerous batteries looking for elevated temps - it's looking for ways to avoid replacing dangerous batteries. We know this because if they were willing to break the law and still are. I think pumpgate gets rid of as much SOC as possible (even more voltage than recalled Chevy batteries are downgraded) to keep the not immediately dangerous packs from costing them warranty money, and only identified batteries they can't keep from thermal runaway.Maybe the diagnostic does both..... High flow to bump down SOC while keeping temps low, then low flow rate looking for signs of elevated temp?
Only batteries that continue to heat up would need to be replaced. A multi-tiered diagnostic plan like this could be called "Advanced Diagnostics."
reducing temperatures until they stop self- heating
But they do need the caps,
