Summary of A vs B battery issue?
Discussion in 'Model S: Battery & Charging' started by pbleic, Feb 23, 2014.
  1. pbleic
    pbleic Member
    Boston
    I just ordered and keep reading references to A and B batteries and an issue with the former.
    Can someone summarize this? Is it "official" or forum speculation?
  2. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    You shouldn't be affected with a car delivered in 2014. But, just to be safe, I'd check the battery pack's part number before accepting delivery.
    There is an exhausting, 144-page thread on the subject. Executive Summary: Yes, it's 'official', and you don't want an A pack.
    Older Tesla's limited to 90kW super charging - Page 143
  3. Cheerose
    Cheerose Member
    Las Vegas, NV
    How can you find the battery part #?
  4. stevezzzz
    Colorado
  5. AndreyATC
    AndreyATC Member
    New City NY, USA
    What's the minimum VIN to assume you have B pack?
    I guess at some point they switched from A to B within certain VIN ranges
  6. FlasherZ
    The "issue" with the first-revision pack is that it is limited to 90 kW charging at Superchargers. For some people, it's a Big Thing(tm). For others, it's not. I have (perhaps had, we'll see what happens Monday) an "A" pack and I'm not particularly concerned because I've supercharged three times in 15 months of ownership. Other people who use them more may care.
  7. Musterion
    Musterion 18h 03m 37s −24° 23′ 12″
    M8
    For 85kWh, the highest reported A battery VIN is mine, 9331. However there were mixed A and B deliveries before then. After 9448, all batteries were B or higher. You can check this table for more details: Battery table - Tesla Motors Club - Enthusiasts & Owners Forum
    Note that the A vs B distinction does not apply to 60kWh, as they are a different part number and were the newer battery types even in original revision.
  8. jerry33
    Texas
    Yes, mine is a B at 5130. Guess I should have purchased a lottery ticket while I was at it :)
  9. AndreyATC
    AndreyATC Member
    New City NY, USA
    I guess it's safe to assume i've got B pack, since my vin is 16xxx
  10. Kalud
    Kalud Active Member
    Montreal, QC
  11. apacheguy
    apacheguy S Sig #255
    So Cal
    Indeed. And just to add to that, there are now concerns regarding a different degradation profile and reliability (as FlasherZ has recently learned). Wrt the former, there is insufficient evidence to reach a conclusion. However on the latter point, we do know that Tesla has replaced a fair number of A packs that have failed. For Sigs, the failure rate seems far greater than 1%, which is concerning.
    Back on topic though, all new deliveries are configured with B or better batteries and you needn't worry about getting stuck with an A.
  12. FlasherZ
    I just want to be fair - the problem I experienced last night has not implicated (yet) the battery pack. It correlates very closely with others who have said that the drive inverter was the failed item and only in certain cases were battery packs replaced. I'll check in when I have more information.
  13. brianman
    brianman Burrito Founder
    The concerns regarding A vs. B are:
    1. 120 kW charging support
    2. Taper algorithm with supercharging (different on A than on B)
    3. Degradation profile
    I don't see #2 discussed earlier in this thread, but it was discussed in depth in the original thread before #3 was even raised.
