Summon cancelled when hand over proximity sensor...
Discussion in 'Model 3: User Interface' started by Dana1, Jul 8, 2018.
  1. Dana1
    Dana1 Supporting Member
    Houston
    I was playing with Summon, and it works great, though I got an error message. It said Summon cancelled due to hand being over proximity sensor on phone. This confuses me a bit. I understand the car is linked to the phone but I don’t understand the bit about a proximity sensor.
  2. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
    Your phone has a proximity sensor, typically located above the screen by the earpiece speaker. It's primarily used to disable the screen during calls when you have the phone up against your face and to detect when the phone is in a pocket/bag or face down to avoid errant screen activations.
    Presumably, the Tesla app checks the proximity sensor when using Summon as a quasi check of being in a pocket/bag. Last thing you'd want is a freak combination of screen presses that accidentally backs your Tesla up remotely without your knowledge. Same reason the S lost press-and-hold on the key fob to lower all the windows.
    • Informative x 2
  3. Dana1
    Houston
    Wow, thanks! I had no idea...love learning stuff.
  4. aronth5
    aronth5 Long Time Follower
    Boston Suburb
    Just got 26.3 and tried to use summon. At first it worked maybe a third of the time then it stopped working completely with the phone proximity error.
    After checking the forum and messing with various settings with no success I took off the Galaxy S8 protective cover off. No luck. So I took a safety pin and very carefully "cleaned" out the proximity sensor.
    Didn't notice any dirt but now it works perfectly. Will have to keep my pockets cleaner:)
  5. crackers8199
    crackers8199 Member
    lake elsinore, ca
    not to hijack the thread, but random question: can you use summon while sitting in the car or do you have to get out and put it in park first?
  6. thimel
    thimel Member
    In a model S you can sit in the car and use it. That is how I first tested it.
  7. Twiglett
    Twiglett Single pedal driver
    Austin
    you can sit it while using summon, it fells odd though :)
  8. Stratto
    Stratto New Member
    St Louis
    How do you clean a proximity sensor?
  9. Stratto
    Stratto New Member
    St Louis
    Remove your case, and remove any screen protector, and clean your iPhone thoroughly. A cloth for cleaningspectacles is one of the best things to use. Check if the proximity sensor is working by making a call whilst stood in front of a mirror, and seeing if the screen dims as you lift your iPhone to your ear.
