Electroman
That vent alone increased the CO2 in the atmosphere enough to melt whole of Greenland glaciers.
That is the opinion of multiple people on the NSF forum. I believe the methane tank is the upper tank on the booster?Ugly amount of methane.
Are you sure that that's what it is?
I would suggest a wink emoji with that post.That vent alone increased the CO2 in the atmosphere enough to melt whole of Greenland glaciers.
CH4That vent alone increased the CO2 in the atmosphere enough to melt whole of Greenland glaciers.
Understood and you are correct. The point is, it is a much more powerful greenhouse gas than CO2
Methane is a powerful greenhouses gas with a 100-year global warming potential 28-34 times that of CO2. Measured over a 20-year period, that ratio grows to 84-86 times. About 60% of global methane emissions are due to human activities.
Agreed. Not happy with large amounts of methane being released. I am surprised it is legal/allowed by the environmental assessment.Understood and you are correct. The point is, it is a much more powerful greenhouse gas than CO2
Top is CH4Is the Super Heavy upper tank the CH4 or the LOX tank?
It may have been CH4 due to location but an unplanned release due to overfill/ overpressure. Turned off pumps too late and value deal with the hammer effect.I'm pretty sure large releases of methane are covered by OHSA. I doubt that is methane/CH4 but is likely LOX. Which is the same as what we see with F9 and RP-1. SpaceX isn't venting superchilled RP-1 during the loading process. So there is no reason to be venting superchilled methane/CH4.
I assume full power is needed to achieve liftoff in a fully fueled vehicle with payload once the OLM clamps are released, so the upcoming static fire will be close to 100%.That will be very interesting to watch.
Any ideas what the engines are throttled up to for a static fire?
15Mil lbs of thrust... wowza...I assume full power is needed to achieve liftoff in a fully fueled vehicle with payload once the OLM clamps are released, so the upcoming static fire will be close to 100%.
I wonder what the dummy payload will be for the first orbital launch attempt? A multi-ton wheel of cheese seems infeasible.
Starship + SuperHeavy's T:W ratio is about 1.5 : 1, so technically it only needs ~67% thrust to lift (slowly) off the pad. But presumably they will test it at close to 100%, to simulate a real launch. Wouldn't want to test at 80% only for the real launch to fail in a way that only manifests at 95%.I assume full power is needed to achieve liftoff in a fully fueled vehicle with payload once the OLM clamps are released, so the upcoming static fire will be close to 100%.
Just curious, how does this ratio compare to FH and F9 and other NASA rockets?Starship + SuperHeavy's T:W ratio is about 1.5 : 1
F9 is around 1.4, FH around 1.6. Saturn V had a thrust:weight ratio of only around 1.2, and used up about 8% of its fuel just clearing the tower! The Space Shuttle (with SRB's!) had a total thust:weight ratio of around 1.5 at liftoff, quite similar to Starship + Super Heavy.Just curious, how does this ratio compare to FH and F9 and other NASA rockets?
It is just a STUNNING statistic.used up about 8% of its fuel just clearing the tower
