That's what I originally saw, but I went off to find a picture of the hot staging ring to show you the three clamps that mongo was talking about. Remember this image? It's a great closeup, and it shows that the external reinforcement was there from the start. You can also easily see the three clamping structures. Starship 25 has six opening for clamps, but neither booster 9 nor the hot staging ring have six clamps. I'm sure that future Starships will have only three openings.So in the crop below, I assume the section pointed to by the red arrow are the reinforcements you are talking about?
Did anyone else notice Brian's hard hat up against the railing in top right of the photo?That's what I originally saw, but I went off to find a picture of the hot staging ring to show you the three clamps that mongo was talking about. Remember this image? It's a great closeup, and it shows that the external reinforcement was there from the start. You can also easily see the three clamping structures. Starship 25 has six opening for clamps, but neither booster 9 nor the hot staging ring have six clamps. I'm sure that future Starships will have only three openings.
Looked like one from NSF slowie...S26 static fire at 3:36PM CDT. Was it only one engine? I couldn’t tell.
Confirmed, single engine burn simulating deorbitS26 static fire at 3:36PM CDT. Was it only one engine? I couldn’t tell.
How would a vent in 1G simulate firing ullage thrusters in orbit at 0G? Or am I misunderstanding what you wrote?If they were trying to simulate a reentry burn, wouldn't they want to be firing ullage thrusters to seat the propellants? Perhaps that big vent prior to firing the engine was simulating that thruster firing, just without any hardware to direct the thrust backwards. During the preburner test the NSF guys seemed to be surprised when they saw that hard vent, thinking it was a depress. It was duplicated on this run.
It doesn't in terms of vehicle dynamics, but it does (somewhat) in terms of vehicle systems.How would a vent in 1G simulate firing ullage thrusters in orbit at 0G? Or am I misunderstanding what you wrote?
Could also be a lower tank pressure (simulating cooled ullage) startup test.It doesn't in terms of vehicle dynamics, but it does (somewhat) in terms of vehicle systems.
To settle propellant, we need X acceleration for Y seconds, that's Z flow of gas at pressure A in a vacuum. Compensating for sea level, vent for B seconds and verify start and stop pressures. Then light engine.
Also, rotate ship for retrograde thrust.
The vents are the thrusters, last I heard.
Given the amount of work that is going to have to go into getting an HLS vehicle to the moon, I'm not sure that a pad test of a retrofire will instill much enthusiasm in NASA. SpaceX has to get orbital, prove on-orbit refueling, and perform eight tanker runs to the final HLS vehicle. I'm guessing that they'll work with an HLS pathfinder vehicle first. They'd use that pathfinder as a target for refueling until they think they have it worked out. Then they can launch HLS, launch the tanker runs, and send it off to the Moon. All the while, they'd be working on reentry and reuse of booster and Starship.But SpaceX has to show NASA that it is making progress with the HLS vehicle so this test will hopefully show that.
Today they did two partial tanking tests plus a deluge system test.S25 has been re-stacked.
