So... in Part 1 of the Everyday Astronaut Starbase video Elon says the grid fins don't fold flat during ascent.
The discussion was that it probably wasn't necessary as they aren't in the flow anyway.
That seems counter-intuitive to my non-rocket-scientist brain, especially when they've ben playing a game of fractional percentages to balance fuel burn to get as much payload to orbit, yet still have just enough fuel to land a booster. Elon talked in the same video about trying to get remaining fuel under a ton, which seems an awfully slim margin.
For the grid fins to effectively steer/help slow the rocket, they have to be in the flow when extended for the return. Even if the grid fins contribute 0.1% additional fuel burn due to drag, that seems like a lot.
Thoughts:
1) This is only not a big deal for the test article that they are gonna dump in the ocean anyway
2) The flow around the fairing during ascent really excludes the fins from producing any drag. On descent the flow is different and they are then capable of producing the drag needed
3) The margins for fuel on the Starship booster are different than for Falcon 9 so that it matters less
4) Other?
Also, these appear to not be titanium... again assuming because of it being a disposable test mule...
The statement is a bit strange but perhaps they will just rotate the gridfins during launch so that they are at 90 degrees to the flow, thus greatly reducing the drag they produce and bringing it much closer to the drag that would occur if they were folded (difference in drag will be related to the gridfin aspect ratio). It will certainly be interesting to see the launchSo... in Part 1 of the Everyday Astronaut Starbase video Elon says the grid fins don't fold flat during ascent.
Thoughts:
Not sure how much of a factor, but I do recall Elon saying somewhere in the Tim Dodd interview, the SH/Starship liftoff would be quite rapid. I'm thinking maybe this beast won't be spending too much time in the atmosphere during the ascent stage, so therefore won't be taking a big drag hit from the grid fins.They simply orient the grid fins such that the air flows right through them on ascent. They only start to orient them to impede airflow on descent.
I first wondered this also, but then came to the conclusion that they rotate them 90 degrees.Ah, interesting... rotating them 90 degrees would certainly reduce the cross-sectional area presented to the flow. Did he say that's what they were going to do and I just missed it?
Because as I recall he didn't suggest rotation as an alternative to folding, but rather that it wasn't necessary at all, because they "weren't in the flow".
I'll have to go re-watch it.
(also interesting to note they are electrically actuated on Starship, whereas on Falcon 9 they are known to be hydraulic. I also wonder that the complete degree of rotation they are capable of is...)
The use of model 3 motors has certainly been said before. So too has the comment re stainless.I first wondered this also, but then came to the conclusion that they rotate them 90 degrees.
Did Musk by the way say that they are rotated by Model 3 motors?
Yeah he did.I first wondered this also, but then came to the conclusion that they rotate them 90 degrees.
Understand that they are primarily control surfaces, but they absorb enough re-entry energy to heat up enough to need ablative paint on the surface of them from before they switched to titanium... and the IR shots of the new ones show them to get pretty toasty.Total effective surface area is likey less with them at 0 vs +/- 90. Definitely a smaller max contiguous area.
Fins are for attitude control on reentry, not so much deceleration.
My understanding was that the spikes on the underside of the grid fins (hence on the leading edge during re-entry) were designed to operate in a compressible flow regime.They're designed to choke at supersonic...right? Or did I totally miss something at some point in history? Maybe that far down the vehicle never goes supersonic?
There is a thing that has been bothering me for a long while.So... in Part 1 of the Everyday Astronaut Starbase video Elon says the grid fins don't fold flat during ascent.
Thoughts:
4) Other?
My understanding is that the landing burn decelerates it to the point that it can withstand the slam it's about to do in the denser part of the atmosphere as well as the combustion gasses are cooler than what the rocket normally would experience due to compression heating. After that it's that dense atmosphere that continues to slow the booster down.There is a thing that has been bothering me for a long while.
I have watched a lot of the launches and landings in "real time" going back to grasshopper, which was filmed, so "surreal time"
during descent, when the first stage is screaming in around 8,000+ klicks, it does an entry burn for what ? 20 seconds or so, to initiate slow down to roughly somewhere around 5,000 klicks
the first stage _continues_ decelerating, like it is riding a bubble of hot compressed air to help bleed off speed (a virtual parachute?)
when it does the landing burn it has bled off most of the speed (and used the grid fins to steer)
Is this what is happening?
Atmosphere keeps getting thicker and it starts above terminal velocity. So it continues decelerating.There is a thing that has been bothering me for a long while.
