Well at least it’s not any GSE on fire, so that’s good news.
A bit surprised that there does not appear to be any effort made to putting it out.
I saw your earlier post about that. Still surprised by that strategy given the relatively low amount of vegetation present in the area but perhaps the location of the fire was too far away from the road to get access to. I do know what a “backfire” is and maybe that is the approach being used to control the fire. Currently NSF livestream isn’t showing anything burning.Read my previous note. They are intentionally going around lighting fire to the brush
It does seem to indicate they are producing some amount of airborne heated debris which needs addressed. The important stuff is surrounded by non-burnables, but kicked up heated materials bypasses those protections. Maybe more Martinite fracturing issues?I saw your earlier post about that. Still surprised by that strategy given the relatively low amount of vegetation present in the area but perhaps the location of the fire was too far away from the road to get access to. I do know what a “backfire” is and maybe that is the approach being used to control the fire. Currently NSF livestream isn’t showing anything burning.
SpaceX is certainly having some fire control issues during vehicle testing. A booster spin prime test resulted in a conflagration directly under the vehicle. Then the first 6-engine static fire of a Starship caused a brushfire. It seems that more attention needs to be paid to understanding and managing ignition sources during testing. At least no one has been injured and as far as we know no major damage has occurred to the vehicles or the GSE.
SpaceX confirms it was a 6 engine static fire.
Starship lost some tiles during the static fire.
Yes, 39-A has flame trench from Apollo/ ShuttleQuestion: Did Falcon Heavy launch pad have a flame trench ?
The rocket structure also flexes with engine force, along with normal cryo induced shrinkage. Losing just a few in isolated areas can get chalked up to process variation.Engine startup must be more violent than I imagined if it causes tiles to pop off. Or I wonder if it's acoustic energy issues?
I suppose the ignition "thump" may give the stack a decent kick in the pants... even if it's at partial throttle.The rocket structure also flexes with engine force, along with normal cryo induced shrinkage. Losing just a few in isolated areas can get chalked up to process variation.
Depends which time frame you define startup.I suppose the ignition "thump" may give the stack a decent kick in the pants... even if it's at partial throttle.
Anybody have idea if the engines are throttled at all during startup, and if so what that level may be?
Here is a side-by-side comparison photo showing where the tiles were lost. Mostly near the base. Given that a full stack launch will have the ship much higher off the ground, and of course the ship engines won’t be active at launch, that may mitigate tile loss at launch.Engine startup must be more violent than I imagined if it causes tiles to pop off. Or I wonder if it's acoustic energy issues?
Flaps are for attitude control, braking is via vehicle crossection. On Tim Dodd tour interview, Elon mentioned they could go smaller in flaps area and possibly eliminate one set.But if it cannot stay glued at this level of vibration, how is it going to stay on during the extremely fiery reentry at 10k miles per hour. Remember they are not planning to have a re-entry burn to slow down before hitting the atmosphere, but hoping to slow down just using the flaps. (that is my understanding). That means it is going to hit the atmosphere at a speed much-much higher than the first stage.
I imagine quite a lot of structural vibration modal analysis went into that.The video in this tweet is slowed down to frame-by-frame to visualize it better. ........... The 33 Engine Booster startup sequence appears to involve 16 different engine groupings. After the center 3 engines ignite, the remainder spin-up 2 at a time (opposite pairs) until all 33 are lit.
For sure; the potential interactions between all those engines must be extremely complex.I imagine quite a lot of structural vibration modal analysis went into that.
Yes, and higher up the structure. Plus of course in the plumbing.For sure; the potential interactions between all those engines must be extremely complex.
