ElectricCanuck
Currently supercharging in cornwall Ontario and occupying one of six stalls. The other five are empty, and I’m seeing 35 kW. Slowest SC I’ve ever seen!
Just moved over a stall 3b to 2b and no preceievable difference.Have you tried another stall? Could be a bad unit.
Also, reporting these to Tesla is probably a good idea. I don’t know if they have any good telemetry to tell when things are broken.
Same thing happened to me today at Petaluma. I have a P3D+ that has free supercharging and today was the first time I used it. I was expecting 110 - 120 kW (SOC was about 30%) at least at the get go. I noticed the charging rate started as usual but then abruptly stopped at exactly 60 kW, went to another stall, same thing. Petaluma is a 20 stall set up and only 2 other cars there (not sharing on either). Has anyone with Performance free supercharging been able to charge above 60 kW? Is TM limiting free supercharging for P3 to tier 1?
I still have not seen you mention what state of charge % you have. Are you somewhere up around 70 or 80%?Just moved over a stall 3b to 2b and no preceievable difference.
OK, thanks. Yeah, 35kW at only 40% full sure isn't right since you weren't paired either. I would say that is worth reporting to them. Sometimes some locations do have power supply problems.
If the ambient temperature is low and the battery pack is still relatively cold, it may explain the slow charging rate also.
Oh yes! Jeez, I can't believe I forgot that part. @ElectricCanuck don't call Tesla yet. Yeah, lithium ion batteries can be severely damaged if they are charged when cold, so every electric vehicle is careful about that. My electric motorcycle has a temperature monitor in the battery, so it just won't charge if it's too cold. There's no battery heater on my motorcycle, so I just have to have it in the garage until it gets warm enough for charging to start. It's a gradual scaling effect with temperature, though, so at really REALLY cold temperatures, it's terrible, and they just shouldn't be charged. If they are a little less cold, you can safely use low power charging, and a little warmer, you can use a bit more power, etc.If the ambient temperature is low and the battery pack is still relatively cold, it may explain the slow charging rate also.
