TitaniumMet
New Member
It's live. I just did a 30% charge from 50 to 80% there this afternoon. Enjoy!
Thanks for letting me know. I’m there now charging finally glad it’s up and running.It's live. I just did a 30% charge from 50 to 80% there this afternoon. Enjoy!
The last two times I've visited this Supercharger it has been painfully slow. Today, my peak speed was 24kW or 81 mph. This is the slowest charging I've ever experienced at any supercharger I've visited. When I speak to other drivers charging, they have the same experience. I know we're discouraged from reporting problems through phone technical support. What's the best way to report the problem?
You should report problems to [email protected]The last two times I've visited this Supercharger it has been painfully slow. Today, my peak speed was 24kW or 81 mph. This is the slowest charging I've ever experienced at any supercharger I've visited. When I speak to other drivers charging, they have the same experience. I know we're discouraged from reporting problems through phone technical support. What's the best way to report the problem?
Yes to all the “yes/no” questions. And my battery was at various states of charge - today it was at 50%. So no reason I can identify for a charge rate of 24 kW. Others I encounter at this station have the same issue. I’ll try the website you suggest. Thanks.You should report problems to [email protected]
Was your battery warm? i.e. had you been driving for at least half an hour before trying to charge. What % of charge were you at when you started? Were you paired with any other car which was charging? All of those things will affect the rate of charging.
If your answer was yes you were paired with another car, that would be your problem. Is that what you meant? If someone is already charging on 1A and you connect to 1B you will only initially get about 25% of the possible max rate until their rate of charge drops.Yes to all the “yes/no” questions. And my battery was at various states of charge - today it was at 50%. So no reason I can identify for a charge rate of 24 kW. Others I encounter at this station have the same issue. I’ll try the website you suggest. Thanks.
I knew that was going to cause confusion as soon as I hit "send"!If your answer was yes you were paired with another car, that would be your problem. Is that what you meant? If someone is already charging on 1A and you connect to 1B you will only initially get about 25% of the possible max rate until their rate of charge drops.
It amazes me how many people don't seem to be aware of this (not saying that applies to you, but I just want to belabor the point, since I've had people connect to the Supercharger next to me which was paired with me, even though there were available unpaired chargers. Usually I tell them, but sometimes I don't.
This is not an issue on Urban Superchargers where the max rate is a dedicated 72 kW for each charger, but on V2's it definitely is.
