What's your source for that?Charging pedestals are still on back order till mid September
No one working at main site. Two-man crew doing cleanup along path of power supply conduit. Leveling and seeding. Talked to them. They said the power conduit work is complete. They don't know what's going on with the charger site. I did see that all 10 pedestal bases are now in place.
Nope.Forgot to ask did the power company set there transformer? (large green box next to Tesla's gear)
Drove by in the rain. Did not want to get wet for better photography. Kindog's description is right on, but notice the green transformer is now in place. Progress indeed.View attachment 445534
Did you see the underground crew working down by BJ's and or is there large black pipe pile gone? it was half way to BJ's.
Yes the mini excavator blocks the view of the utility transformer. I cant see it either. it was the third concrete pad. EDIT I went back to the picture and the pad would have been to the left of the excavator.
When this site is done I wonder how much pressure if any it will take off of Gaithersburg. that place is always full.
That is big progress. Now all the cabling from BJ's and the switchboard can be done and terminated. Good deal. They could possibly get a service inspection and set the meter and turn on the juice while we sit and wait for those backordered pedestals.
Does anyone know if these will be 250 kW chargers or the newer higher power chargers? Given they cut the number of pedestals back from 12 to 10 and the pedestals are backordered, I'm wondering if they aren't installing 350 kW units?
The newer chargers you’re referring to are 250 kW. The ones being installed in Frederick are the standard 144 kW. Leesburg is 72 kW.
BTW, I'm not doubting you, but how do you know the Frederick chargers will be 144 and not 250? Is this indicated somewhere?
I see you're a new member. Beg your pardon if you already know this: efficiency on short jaunts is low when it's cold outside. And when it's hot outside. It takes considerable energy to bring the inside of a cold car up to 70°. And to bring the inside of a hot car down to 70°. If you're plugged in, turn climate control on before departure.Leesburg actually will keep me happy if I can't get to Haymarket. But I'm getting concerned with my range. I've been watching it more closely and I'm just not getting anywhere near the miles I should get. Isn't it in the winter when the range goes down so badly?
I see others have previously replied with some advice. Also note that short trips use more energy than longer trips. The way you drive also has a huge effect on range. Your heating and AC system settings also have an impact. If you leave the car sitting with camping mode on or dog mode on, that'll turn also cause a spike in the usage numbers when you go again.Leesburg actually will keep me happy if I can't get to Haymarket. But I'm getting concerned with my range. I've been watching it more closely and I'm just not getting anywhere near the miles I should get. Isn't it in the winter when the range goes down so badly?
