The manual says that if you drop the pin or touch an existing pin on the map you can see info about the place, the phone number and working hours.
When I tap on the existing POI pins, it doesn’t show anything. If I drop the pin on top of the existing POI, it will sometimes show working hours, but not the name of the place or phone number. The only place where I was able to get all that info was when you access it from the search results.
I’m on software 2019.16.3.2. Is it working on other versions?
